Lone Wolf
- Jan 31, 2015
- Reaction score
- 0
- Make / Model
- Ford
- Manual
I bought a 94 from a coworker. It had quit running and some idiot told him the engine was locked up. It sat for around 3 years. I bought it for $600. The only problems found were the starter solenoids were both bad. The fuel pump had also gone out from sitting. Besides that I changed the plugs and wires, fuel filter, fuel filler hose, and poured some seafoam in the tank. It fired up and ran like a champ. I drove it around the neighborhood a few times test driving it. It needs tires before its really roadworthy.
It started sputtering like it wasn't getting any gas. I went to back it into place and stalled it out(I haven't drove a stick shift in a few years). It wouldn't start back up. I was thinking it was a fuel problem. I tried starting fluid and it wouldn't start. I started checking wiring harnesses and plug wires to make sure everything was connected. Then it started. I let it run for a few minutes, shut it off, and it started back up. I turned it off again and it wouldn't start.
I pulled a wire to see if I was getting a spark. I asked my wife to start it. It fired right up for her. shut it off and replaced the spark plug. It fired up again. I was standing beside it and it died. No sputtering or anything. It just shut off.
where should I start with this? Any Ranger specific problems that I should look into first? Will the MAF cause it not to run at all? My experience with MAFs has just been rough running. Cars would still start.
