Unhook battery Negative for 5 minutes or reboot computer if you have a Scanner.
See if it was a computer glitch
Not sure what your numbers mean??
14 and 147
Pulse width is based on fuel pressure and injector size, these are "assumed parameters" programmed at the factory, 3mSec at idle and up to 9mSec accelerating to higher RPMs.
At 2,500 rpms held steady about 5mSec
Computer can adjust these based on O2 sensor results, that shows as the +/- fuel trims.
Longer pulse width would mean low voltage from O2(lean exhaust), under .40volts
That would translate as + fuel trims, more fuel added
Clear Flooded Engine Mode(in all EFI computers)
Turn key on
Press gas pedal to the floor and hold it down all the way, computer will turn fuel injectors off but leave spark on.
Crank engine
If engine fires you have a leaking injector.
As soon as you let off on the gas pedal injectors will start.
