Swapped my 99 4x4 axle shafts that have retainer clip for explorer shafts with nut
Cagle
Ranger 4.0
I needed cv axle, hub, rotor, caliper, caliper bracket, for passenger side of my 1999 ford ranger 4.0 ext cab truck. I went to a local pick and pull but didnt have the exact axle and hub. However they had a 99 explorer eddie bower 4x4 on hand and everything looked like it would fit my ranger so I went ahead and got both sides of it because my drivers side cv boot was toast anyway. The only thing I see different are the hubs and axle nut. I had switched to manual locking hubs (AVM'S) I think thats what their called made by rugged ridge a while back due to the pulse vaccum not working. Those wont work on the axle shafts I just went and got. That's the only problem I see. The rest should work just fine shoudn't it ??????? Thanks for any advice. :beer:
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
As far as I know it will all work. You would effectively be swapping to a live axle set up. The Explorer used a center-axle disconnect system, but that should not have any bearing on your setup because the actuator was in the axle tube, not at the wheel ends.
Staff online
Shran
April Truck of The Month
