OBD1 code 89 in my 86 2.9l std tranny pickup issues
2
I'm getting code 89, which is Exhaust Heat Control (heat Riser) solenoid circuit
I cannot find this on my truck, I cannot find info on it anywhere, maybe you fellas can lend a hand.
Engine bucks at any throttle over 2/3 rds. full throttle falls on it's face...
New TPS, New EGR, new EGR sensor, New Fuel pump 39# constant (second fuel pump in a row), New (third in a row) Pressure regulator.
Any thoughts?
Free flowing exhaust, it's not a clogged catalytic converter, this is a throttle issue somehow, it's not popping, it's Bucking basically anything past half throttle...
Thanks fellas!
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
MAP sensor could be on the way out. If it is giving bad readings at high throttle that will mess with the fuel calculations.
2
I guess it cant hurt. Ordered up. Ill let ya know.
Meanwhile this code 89.... any clues on what the heck it is ??
2
I don't know if that first reply went in so I just ordered a map sensor just in case and why not with a hundred thousand miles on it might need it. Any idea on this code 89? I can't find any information on it and this truck does not have an exhaust heat Riser on it
2
Well brand new map sensor and still flatlines when i gp full throttle.
ANYONE????
2
OK 4th Fuel pressure regulator is only giving me 32 psi KOEO, and 28 psi KOER...
I ordered every single fuel pressure regulator form Oreillys, they're the Borg Warner 51 dollar unit, and I'm not stopping until one get's me to 45 PSI minimum.
I can reduce the return fuel flow and get 45 psi and the truck run's tits up to the nines, so I am calling it a regulator issue.
Still no idea on this Code 89 the damn computer is telling me. I'ts a brand new Borg warner EGR valve, and a new EGR vacuum sensor, and this truck does NOT have a Heat Riser solenoid.... nor can I find any evidence of it ever having one.....
Paulos
210
North Carolina
1987 STX
Ranger
Engine Type
2.9 V6
2WD / 4WD
code 89
Code 89 (key on) in the Innova code reader book shows
AXOD Lock-Up Solenoid (LUS) circuit failure or
Clutch Converter Override (CCO) circuit failure or
Exhaust heat control
Code 89 (key on) in the Haynes Ranger manual shows only
Hopefully you have an auto trans in your Ranger, as this would explain the code. I've had '86 and '87 Rangers with the 2.9 (but no auto trans) and have never heard of exhaust heat control, or ever seen code 89.
Have you replaced the O2 sensor? Also, I've personally never heard of a FPR on an '86-87 getting more than 39-40 PSI. If you got 39 it should be more than sufficient.
I just noticed the title in your first post staing you have a standard trans. Maybe the computer you have is for an automatic trans Ranger.
2
It is a 5 speed standard transmission you look up the codes and it says heat Riser control solenoid there is a third one if you look up OBD1 specs....
This did not have a converter of any type :)
2
I've put in FIVE new BW fuel pressure regulators. It sits at a solid 38 psi key on engine off, it drops to 27-28 psi with engine running and vacuum line hooked up.
Everything I can find said 35 to 45 psi.... How can i achieve this?
2
It's NOT the lift pump, if it was, then I wouldn't get the pump to push over 70 psi when I gently restrict the return line.....
I need ideas folks 8)
rusty ol ranger
2.9 Mafia-Don
7,658
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
A legend to the old man, a hero to the child...
Heat risers were used on carburated engines to help open the choke. No idea why you would be getting that code off a 2.9.
You change your fuel filter?
JerryC
56
Tennessee
2.9
Ditto on the fuel filter, my 88 has two of them.
You tried several regulators but have you tried a different gauge?
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
2.9 has a heat riser for cold starts. but should not code, as its a mechanical bimetal sytem vac switch with vac motors..like many eec4 systems.
bad pcm or wrong pcm possible though...
Any thoughts?
Thanks fellas!
holy fawking fawk:icon_surprised: i feel for ya brother... seems you probably narrowed things by restricting the return line to raise pressure and it ran correctly...or better as it were. going to an aftermarket inline regulator may workout ok....like this......
https://www.summitracing.com/parts/tnk-afpr1?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-tanks-inc&gclid=EAIaIQobChMI9veQps-O2wIVT1uGCh2pYglAEAQYAiABEgLCU_D_BwE
or maybe not. the low fuel psi (unless your gauge is inaccurate) could simply be low voltage..which will burn the wires or pump up eventually by increasing the psi/load...
but please remember...
....even if you empty the parts store, its not going to fix a wiring or incorrect pcm issue or incorrect timing or crossed ignition wires.... or wiped out cam lobes...shit valves or wiped pushrods, plugged or wrong injectors ect...
if the the plug wires are bad or crossed or the cap/dizzy reluctor is fawked or it has the wrong tfi....new fuel injectors because yours are clogged to the max... i guess someone can get lucky when they get to buying those...but that is a painful amount of wasted cash.
could be a simple large vacuum leak which could read as a bad map sensor or hamper fuel pressures....
i would suggest you...buy and learn how to use a dvom.
get a vacuum gauge
study the spark plugs
were you having wild swings with fuel pressure this whole time? without doing proper fuel pressure load and volume testing i cant imagine buying any parts unless obviously dead... what your investing here is perplexing. would suk if they are just giving you the wrong part...
New TPS,
why? was it erratic on a meter test?
were these tested?
the valve hanging can cause some stumble and actually some of what your describing...one way i test.....slam it shut for testing or put a plate to block it off to make sure...but i am not thinking this is an issue.. you will actually get stumble when its closed and the sensor reads open as the engine rates fuel and ignition for the egr flow...
you can bridge it with a resistor to delete it. the eec4 is really robust and minimal ..
well these damn things are sometimes dead in the box..so i can see running through a few. but as long as your holding 33 psi at wide open throttle you have plenty of pressure...now volume is a whole different issue. are you using a gauge you can monitor driving under load?
volume test can be key here, poor wiring can cause a volume deficiency under load with good psi on idle testing and even load test for short periods...shitty grounds or just corrosion can cause it...bad connection through the rollover switch can cause power delivery issues. when i suspect it i run a temporary clean power setup to eliminate the possibility of it causing diagnosic issues. of course a proper voltage drop test can be effective but i just bridge it with direct wire system fused of course when in doubt.
so your new fpr kept failing and dumping fuel into the intake? or were you just loosing pressure at wot?
with a vacuum gauge on it, whats it look like...??? there are tons of pictures and write ups on how to use the vacuum gauge and read plugs.
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
