SOLVED: Serpentine Belt Tensioner problems Squealing
RedRider
Well, I have one more post to help solve problems, after that I am going to a begging mo fo! :) I really need to title this... "WHO WOULD HAVE THOUGHT THAT CHANGING A FRIGGIN BELT WOULD BE THIS DIFFICULT".
I tried to change the serpentine belt on my truck with 70k miles. I bought a standard belt at Autozone. The problem that happened is that after I changed the belt, my truck would routinely squeal loud until it caught up with the engine rpm. After that everything ran fine. On humid / rainy days, the squealing would last much longer.
I was really annoying my neighbors with this squealing noise so early in the morning, so I bought a 'high end' Gatorback belt. Well... the same thing happened.
What is a person to do? If you go by the folks at an autoparts store you need a new tensioner! WRONG!
I actually bought a new tensioner but, on the way home I was thinking I need to stop at Ford and compare belt sizes! I did and guess what, both belts bought from Autozone were about 1 to 2 inches longer than the belt that Ford sold. The serpentine belt at Ford cost $40.
I went home and put the Ford OEM serpentine belt on, and sure enough the squealing went away... forever! I never needed to replace the tensioner, the problem was the belt size!
If anyone has this same problem please post specifics about your truck. I have a 2002 4.0L SOHC 4wd. Back in the day, when I went to Autozone.com and this model was in the MINORITY now it is the majority, so I wonder if they were pulling a part number from a different model truck??
I STRONGLY suggest measuring up your old serpentine belt with the replacement.
I hope this info helps someone in the future.
Cheers
-Brian
WIEGS
Michigan
I think they might of given you the belt for an OHV thinking it wouldn't matter. I dunno just an idea. Whats the length of the belt anyway?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
We have run across this problem a few times where i work ( ford dealership) when we were out of stock on certain belts or customers would install napa belts and have them squeel. The aftermarket belts seem to be a bit longer than the OEM's
Greatbear
No more belt Squeel !!
I was at wits end with this truck making noise. I found out that the belt dimensions make a big difference and not all auto parts stores follow the Ford standard for these. When i looked up NAPA i found their MICRO-V AT belt and put it on. (it is made by Gates). NO SQUEAKS, NO SQUEAL, NO MORE @#$% Noise. There is a god who drives a Ford. lolhttp://www.therangerstation.com/forums/images/smilies/yahoo.gif
SnC RangeR
5
south eastern nc
same thing happened to me, i learned the hard way.
S197GT
old post but bumping for anyone who might run into this problem.
this is my first post and i just got a 2001 4.0 SOHC with 201k miles. motorcraft belt had obvious wear in the grooves so bought a continental belt from amazon. amazing construction/quality but started to squeal at startup.
bought a new tensioner pulley thinking that was the issue. squealed even worse at startup!
took belt off and compared it to old motorcraft belt. definitely 1-2" longer. i had just put in an exchange for a gates brand and then i found this thread. looks like i should be in the clear...
jcrow123
Sqealing Serpintine
Yep, the aftermarket tries to make a belt that will fit a large range of models. Just not Ford Rangers.
My old Goodyear Gator-back "quiet belt" wore out so I hooked it into a local auto parts store where they sold me a "Premium" replacement for about $35.. Let the squealing begin! Finally bought a replacement from Ford for @ $45 but only after they tried to sell me a new tensioner. Problem solved.
The Gator-back also works but is no longer made by Goodyear, now it's Continental or ContiTech the part number is the same though, the one that fits a 3.0 l with/AC is Continental part number 4060887 same as the old Goodyear part number. Rock auto has 'em online for @ $21 I don't know what the part number is for NO/AC but they are still called GATORBACKS so it should be fairly easy to find.:beer:
There are two part numbers 4060882 = 88.2" and the 4060887 = 88.7" effective lengths
I wish that people who list replacement belts that fixed the problem would include info about effective lengths and actual part numbers which makes the info much more useful. Just saying
Kirby N.
March Truck of The Month
