Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-04-2017, 09:06 AM   #1
spottedsquirl
Junior Member
spottedsquirl is on a distinguished road
Default Under hood clearance for needed intake mod
Hey all, I have a 94 3.0 5speed rwd. My oem intake tube is basically held together with electrical tape and now is the time to upgrade. I'm doing my own set up and am in need of clearance measurements from the original location of the oem tube between intake and airbox. I'm looking into running a 2.75" tube, will there be enough room for this or do I need to go another direction? I am on a strict tight budget and cold air intake kits are not an option at this time. Thanks.
spottedsquirl is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-04-2017, 11:40 AM   #2
RonD
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
You already have a Cold Air Intake, just FYI
Yes, you can make a new air tube, and make it fit.
Popular DIY is using fiberglass cast material, very light weight and easy to work with, cheap
Video here: https://www.youtube.com/watch?v=BbZdbiby7P4
Just put a board across from fender to fender to get clearance
RonD is offline   Reply With Quote
Old 12-04-2017, 12:14 PM   #3
cbxer55
cbxer55's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
I use this vehicle for: Everything
cbxer55 is an unknown quantity at this point
Default
Don't know what the clearance is on the stock tube. How would you even measure that? I have a 3.0 inch tube on my intake, with a large stainless steel mesh cone filter on the end. Have to lift the tube a little every time
I install it to keep it from hitting the alternator pulley. It's never hit the hood.
This is an old picture, but still the same MAC intake. Just a different filter these days. Also replaced the sleeves with new black ones this year, and used T-Bar clamps on the entire intake. Sure is a lot of junk under the hood of these trucks. My Lightning looks so much cleaner.
__________________
1998 3.0 Ranger Sport
2004 Ford SVT F-150 LIGHTNING
2006 Suzuki M109R
2008 Suzuki B-King
cbxer55 is offline   Reply With Quote
Old 12-04-2017, 05:06 PM   #4
spottedsquirl
Junior Member
Default
Thanks for the info n replies! I am building a new intake tube n now have the info I need to get started. Thanks again!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Does the Edge/Powerdome hood have more clearance Nozzleman General Discussions 1 08-23-2016 09:02 PM
howl from under the hood - possibly with intake tract? 92 5 oh 4.0 Liter Forum 16 07-27-2014 03:38 AM
2.9L to 4.0L swap into '89 ranger...hood clearance??? wyotecher20 4.0 Liter Forum 2 04-11-2010 11:34 AM
2002 4.0 V6 Want to Install hood intake TechmanDan Forced Induction 2 01-02-2010 09:02 PM
hood scoop intake induction? ncsdaonex 4-Cylinder (2000 & Older) 38 02-23-2009 02:33 PM
1999-2018 / 959 Media LLC / All Rights Reserved
