Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-06-2017, 10:07 AM   #1
drmayf
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger Splash
I use this vehicle for: Shop run around truck
My credo: Happy life? Happy wife!
drmayf is on a distinguished road
Default How to tell when timing chain needs replacement?
Not new to fords, but new to the Vulcan 3.0L engine. I have replaced many from 260 to 351 v8 engines and also the big FE engines as well. All those had very little slack in the timing chain. But when I removed the timing or front cover from my Ranger, owned since new, this chain seems to have a lot of free play or slack. Engine only has 84000 miles on it. So the question is, is slack in the timing chain normal or does this puppy need to be replaced. I am that point in disassembly and installing one would be relatively easy. But if not needed...
So, what is the recommendation for me regards the chain "tension" and replacement? Is there some kind of slack measurement or ? Reply quickly as I have to order one.
Thank all ya'll
drmayf
_________________________
drmayf
Worlds Fastest Sunbeam, period.
204.913 mph flying mile average speed
210.779 mph exit (not top) speed
drmayf is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-06-2017, 01:50 PM   #2
cbxer55
cbxer55's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
I use this vehicle for: Everything
cbxer55 is an unknown quantity at this point
Default
Don't know the answer as to how to tell if it needs replacing. My 98 3.0 has 153,000+ miles on it, no issues at this time. No indication at all that it needs a new timing chain. I would say that the cam position sensor is more apt to need replacing before the chain ever will. I've heard there's a noise that 's a giveaway when that needs to be replaced. With my bad hearing, and a hearing aid that has noise cancelling, I don't know that I'd hear anything that would tell me something needs replacing.
__________________
1998 3.0 Ranger Sport
2004 Ford SVT F-150 LIGHTNING
2006 Suzuki M109R
2008 Suzuki B-King
cbxer55 is offline   Reply With Quote
Old 12-06-2017, 02:22 PM   #3
RonD
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
OEM 3.0l Vulcan timing chain runs $30-$40 on Ebay
If you are asking then it might benefit to get a new one, it will have less slack, BUT(big but)........
Timing chain issues on the 3.0l Vulcan are pretty much non-existant, so does it need one?
No test that I know of, probably is one just never read about how much slack movement is too much.
I would not replace it with 3rd party chain no matter what, new OEM or leave it alone
RonD is online now   Reply With Quote
Old 12-07-2017, 09:43 AM   #4
drmayf
Vehicle Year: 1997
Vehicle Make: Ford
Default
Thanks for the replies. I have decided to leave it alone for now. Using the "if it ain't broke....." philosophy it will probably last longer than me.
drmayf
Old 12-08-2017, 11:55 PM   #5
pjtoledo
Premium Member
Vehicle Year: 2000 2005 199
Vehicle Make: Fords
Vehicle Model: Rangers Taurus SHO 5spd
I use this vehicle for: going to Cabelas
My credo: get outta my way, I'm falling!
pjtoledo has a spectacular aura aboutpjtoledo has a spectacular aura about
Default
ford manual has a procedure to check wear. it amounts to the how far the crank moves while the cam doesn't. limit is 6 degrees of crank rotation.
pjtoledo is offline   Reply With Quote
Old 12-10-2017, 12:26 PM   #6
Rearanger
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger 3.0L
Rearanger is on a distinguished road
Default
Quote:
How would you measure that? If the crank is turned to align cam/crank sprocket marks would the cam mark be lagging 6* when the crank mark is aligned?
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS,
P235/70R-16, Synthetic fluids, 91.5k miles
Rearanger is offline   Reply With Quote
Old 12-10-2017, 08:37 PM   #7
pjtoledo
Premium Member
Vehicle Make: Fords
Default
per Chiltons, same as my Ford book:
remove left-driver side valve cover
loosen #5 cylinder exhaust rocker arm, 4th one back, and move out of way
mount dial indicator on pushrod
turn crank clockwise until #1 is at TDC, harmonic balancer should be at 0
timing chain should now be tight on right side, 4-5-6
zero dial indicator
slowly turn crank CCW until dial indicator moves, smallest movement that can be detected.
check how far harmonic balancer timing mark moved, should not exceed 6 degrees.
6 degrees on the short radius of the crank gear isn't much, the timing dots will still be closely aligned.
I would think that devising a way to lock the cam and measure the crank movement would also work, if the front cover is off.
as the cam rotates thru opening-lobe vs closing-lobe actions it will snap back and forth causing the timing to jump around.
Last edited by pjtoledo; 12-10-2017 at 08:42 PM. Reason: oops, and some more B. S.
Old 12-12-2017, 10:01 PM   #8
det107
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: Ranger Edge
I use this vehicle for: DD, Hauling scrap metal
det107 is a name known to alldet107 is a name known to alldet107 is a name known to alldet107 is a name known to alldet107 is a name known to alldet107 is a name known to all
Default
I had a 100,000 mile "tune up". It consisted of replacing the water pump, idler pulley, new belts, new gaskets at a friend's garage. It was noticed then that the timing chain had slack. Of course sprockets & chain was replaced.
I use this truck for hauling heavy junk & there are times it idles for the longest time.
But the timing chain slack is still a mystery-
det107 is offline   Reply With Quote
Old 12-12-2017, 10:13 PM   #9
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
There is no specified service interval or amount of play, like with the belt, in the book. The answer to the question is "When the front cover comes off".
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 12-13-2017, 05:41 AM   #10
Rearanger
Vehicle Year: 2003
Vehicle Make: Ford
Default
It's been a long time since I owned a timing chain vehicle, but when I did it never needed replacing. New vehicles now have gone back to chain over belt - a welcome change, except for the repair shops.
I'd think for checking slack just pinching the chain between the sprockets and measuring the distance should be enough, but you'd need a spec.
Looking at pjtoledo's check procedure it's easier to just replace.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1993 3.0L - stumble after timing chain replacement bennie 3.0 Liter Forum 7 01-30-2016 03:26 PM
2.9 timing chain replacement. jdc215 2.9 Liter Forum 2 04-07-2010 07:07 PM
ranger 2.8 timing chain replacement william_leshayne 2.8 Liter Forum 6 12-23-2009 06:33 PM
2000 4.0 Timing Chain Replacement Help Practical2000 4.0 Liter Forum 1 09-27-2009 05:12 PM
timing chain replacement spaz1879 2.9 Liter Forum 5 06-11-2009 08:43 PM
1999-2018 / 959 Media LLC / All Rights Reserved
