2.9 Y pipe on 4.0ohv?
YungICY
2.3
Does anyone know if the y pipe off a 86 2.9 will fit the exhaust manifolds for a 91 expo 4.0? I can make the rest of it work as long as it'll bolt up to the engine.
It should. I was talking to 4.0B2 about two weeks ago asking about his setup and he said he used the 2.9 Y-pipe on his 4.0 swap.
kunar
131
Toledo, Ohio
5.8l
Yes, it definitely will. My stock 87 2.9 y-pipe is bolted to my 91 4.0
YungICY
2.3
Awesome. Thank You guys.
SenorNoob
548
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Another confirmed here. My 88 Y-pipe is bolted to my 94 engine...
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Not that you need me to confirm it but any cologne engine Y-pipe will bolt to any
cologne engine with factory manifolds...
even a 4.0 SOHC Y-pipe bolts onto a 4.0OHV and thus also a 2.9...
I fixed a friends '85 BroncoII with a 2.8 by using a 190 4.0 Y-pipe and
an 89 Ranger (2.9) cat on it...
