atvkid4eva
- Sep 27, 2008
- Reaction score
- 0
- Location
- Twinsburg, OH
- Make / Model
- Ford
- Engine Size
- 2.9l V6
Hey guys i have an 88" 4wd ranger and the clutch master cylinder is cracked at the top nipple and needs replaced..so my first thought was to remove the clutch line from the slave cylinder and just install another whole unit..well thats not gonna work because the white clip holding the line on the slave is mangled up and WILL NOT come off ive tried and tried..so now i think im just going to get a new master cylinder and knock out the little pin that holds the bottom line on the cylinder..this would leave the line connected to the slave and then i would just have to bleed the system all together which i guess i my only option..does that sound like it will work? and what do you guys use to get the pushrod disconnected from the pedal and the small pin out of the master cylinder? thanks in advance!
