clflorida
- Apr 27, 2014
- Reaction score
- 0
- Automatic
Wasnt too sure where to put this, but I figured exterior was close enough.
(Story)
So I bought a low pro qt Truxedo cover for $480. Knowing it only requires no drilling and opening of tailgate to remove, I needed a lock for my tailgate. So I bought a pop&lock PL2130 that installs in 15 minutes. After trying for 4 hours and getting help from the tech support, I couldnt get it to work. So Im sending it back. Maybe Ill look for another lock, maybe someone will just steal my cover. Oh whale.
After putting everything back in like it was and shutting the tailgate, I couldnt get it open without going inside and pulling the scissor mechanism together.
(Problem)
I can open and close the tailgate if its shut...softly/lightly. If its slammed, it wont open. Ive tried everything I know except replacing stuff.(duct tape, tightening down, wd-40) When the tailgate is slammed, something happens and the passenger part of the scissor mechanism lifts up just enough or the handle latch(?) comes loose and the handle latch slides underneath the scissor and doesnt push down the scissor, opening the tailgate like its supposed to. So what do yall think needs to be replaced/messed with? Im not too sure what all this stuff is called.
(Problem)
When filling up with gas, the gas spills and drips underneath truck. Right where you stick the gas in, underneath the fuel cap and truck, is duct tape where someone tried to cover up the hole/tear. I have no idea what this thing is called. Ill probably need to take a picture but if yall have any ideas that would be kool.
(Story)
(Problem)
(Problem)
