Bleeding Brake Problem/ right rear wheel only
Cricket
1995 Toyota Tercel
New brakes all around but when bleeding brakes fluid came out front two plus the left rear. Nothing came out of right passenger rear.
Can someone tell me what the problem may be & how to correct this issue.
Thanks,
Cricket
AzLizard
12
TUCSON, AZ
1985
4.0 2.8
Do you get fluid if you take the bleeder valve out?
Cricket
AzLizard / Bleeding Brake Problem
No fluid coming out / Installed new wheel cylinder. Still no fluid coming out.
Any other suggestions?
Thank you. I appreciate the help.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Start the engine and try bleeding it. Something is obstructed and starting the engine will give you a few thousand extra pounds of pressure on the blockage.
Cricket
Thanks for responding.
I have even hooked up the air compressor and the line is clear.
If you can think of anything else I would appreciate any help you can give.
Thans
Soledad
2.3L Duratec
If you've got a new wheel cylinder and have found the line to it to be clear then I would suspect a blockage in the master cylinder, proportion valve or something wrong in the ABS unit. I'm assuming a 95 Tercel has a proportion valve or ABS unit.
You could theoretically use a pressure bleeder and do a reverse bleed. Instead of hooking up the pressure bleeder to the master cylinder, you'd hook it up to the bleed valve on the wheel cylinder.
Staff online
Today's birthdays
Shran
April Truck of The Month
