Finally my turbo engine is getting putting together
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
I BUY THE BLOCK OF THE 2.3T LIKE 3 YEARS AGO LOL,AND WAS IN HOLD THE PROJECT :icon_rofl::icon_rofl::icon_rofl:
THE PART LIST
BLOCK FROM MERKUR 87 I THINK
HEAD FROM 89 THUNDERBIRD TURBO
CAMSHAFT FROM 93 WITH ROLLER ROCKERS :D:D
MANIFOLD FROM THUNDERBIRD 89
BIG VAM ;) FROM BMW ;)
ECM FROM THUNDERBIRD BUT IS AUTO (LB2)
TURBO T3 ,EXHAUST .63
WIRE HARNESS FROM MUSTANG 93 AUTO
ALWAYS I TAKE FOREVER WITH MY PROJECTS :icon_rofl::icon_rofl: ,I START LAST YEAR PUTTING TOGETHER THE ENGINE,AND NOW WITH 2 BABYS IS MORE HARD TO HAVE SPARE TIME I HAVE A NEWBORN OF 5 MONTHS NOW :headbang::headbang:
I SAW THE CAR(MERKUR) IN THE JUNKYARD AND THE ODOMETER SAY 87K,AND I DONT BELIEVE WHEN SOMEBODY TAKE HEAD AND LOOK LIKE THIS
I OPEN THE ENGINE,AND HAVE ALL MEASUREMENT OEM SIZE!! THE MAIN BEARINGS AND ROD BEARINGS WAS STOCK SIZE AND FROM FACTORY HAVE THE FORD STAMPS IN THE BACK,SO I PUT NEW RINGS,NEW MAIN AND ROD BEARINGS!!
AND I AM LITTLE LAZY TO CLEAN REALLY WELL THE TOP PART OF THE PISTONS ;)
I BUY THE HEAD FROM CRAIGLIST AND WAS FROM 96 AND UP THE ONE IS SMALL AND VALVES AND SPRINGS AND THE MANIFOLD INTAKE DIFFERENT PATTERN,AND ROLLER ROCKER SMALLER :(
IN ONE OF MY WEEKLY WALK AROUND AT THE JUNKYARD I FOUND A THUNDERBIRD TURBO ;) ,AND I TAKE ALL THE TOP PART OF THE ENGINE (INTAKE,EXHAUST MANIFOLD,TURBO AND HEAD),FOR MY RUSH AND I DONT CHECK THE CAM AND FOLLOWERS HAVE A LOT OF WEAR :(
I SCORE OTHER CAM IN THE JUNKYARD WITH NO WEAR AND ROLLER ROCKERS FROM A 93 RANGER ;)
LET SWAP THAT CAM ;) (YOU LIKE MY EXPENSIVE BENCH RIGHT ;) )
WITH CAM AND ROLLERS ON IT ;)
I SEND TO THE MACHINE SHOP THE HEAD AND WAS IN GOOD CONDITION THE HEAD AND I REUSE ALL THE VALVES AND GUIDES!! ONLY WAS TWISTED FOR THE OVERHEATING,AND SENDING BACK LOOKING LIKE THIS!!
AND NEXT TO THE OTHER HEAD :( (IS LONG GONE I SOLD ON CRAIGSLIST AGAIN AND GAIN COUPLE BUCKS )
I PUT TOGETHER THE ENGINE AND USE FELPRO GASKETS,AND TORQUE TO THE SPECS !!
NOW IS ALMOST COMPLETE AND I HAVE LIKE 5 MONTHS I DONT TOUCH THE ENGINE :sad: ,ONLY I NEED TO PUT THE RAIL OF INJECTORS AND MODIFY THE WIRE HARNESS BECAUSE IS NOT FROM A TURBO CAR!!
THAT BLOCK WAS V BELT AND MODIFY TO BE SERPENTINE BELT!!
simpler=better
Mercedes
This is going to be good :)
I like your workbench, I have the same one in green :)
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
IN ONE BEFORE LAST PIC,NEXT TO THE ENGINE IS SOMETHING COVER :yahoo::yahoo: ,AND IS A 2.3 TURBO DIESEL ENGINE OTHER PROJECT :icon_twisted::icon_twisted: AND I READ YOUR POST WITH THE MERCEDES ENGINE,PRETTY GOOD PROJECT TOO
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
I am too lazy
I AM BEING TO LAZY :icon_rofl::icon_rofl:,AND I DONT DO ANY ADVANCES IN MY ENGINE,HERE IS THE PICS OF MY BROWN TOP INJECTORS,I THINK ALWAYS IS GOOD HAVE A SPARE ONES LOL :yahoo::yahoo:
P.S I NEED TO CLEAN THE INJECTORS AND RAIL TOO
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Not being mean, but is English not your first language? Also looks good.
Sent from my SPH-L900 using Tapatalk
scotts90ranger
RBV's on Boost
4,227
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
He's from Mexico, not doing too bad :)
Not a bad start, it's best to do things right the first time, not the second like I did...
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Stupid tapatalk, doesn't let you see the user info.
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
I DECIDE TO STOP TO BE A LAZY AND PUT THE TIMING BELT OF MY ENGINE,AND I FOUND A PROBLEM :annoyed::annoyed: ,MY CAM AND GEAR IS FROM A RANGER 93-94 LOL,AND THAT GEAR ARE ROUND TOOTH,AND THE CRANK AND THE OTHER SPROCKET IS SQUARE TOOTH,AND THE BELT I HAVE IS ROUND TOOTH :(
I TRY TO PUT THE BELT AND DONT MATCH WITH THE BELT AND DISCOVERY IN THE HARD WAY THE ROUND TOOTH BELT AND SQUARE TOOTHS GEARS DONT WORK :bawling::bawling:
P.S I CAME FROM THE JUNKYARD AND I DONT SEE ANY 2.3 ENGINE FOR TAKING THE CRANK AND THE OTHER GEAR FOR HAVING ALL ROUND TOOTH GEARS :( ,FOR THE GOOD SIDE I STILL HAVE IT THE OLD CAM WITH GEAR,NOW I NEED TO BUY OTHER BELT BECAUSE I LOST THE TICKET :(
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,030
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Too bad about the belt.
It takes me a long time to finish projects too.
Richard
scotts90ranger
RBV's on Boost
4,227
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
If you have another stock cam pulley, put that on the aux shaft as it's the same thing, the square crank pulley should be a little more forgiving. I think I have a spare crank pulley if you REALLY need one, don't know how much shipping would be, and I'm not sure if I know where the pulley is right now :)
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
YESTERDAY I BUY OTHER BELT THE RIGHT ONE,AND PUT THE OLD CAM GEAR,AND PUT THE TIMING BELT ;) ,.TOMORROW I WANNA CLEAN THE INJECTORS AND THE RAIL,AND AFTER THAT I THINK ONLY I NEED TO START TO WORK IN THE WIRE HARNESS :yahoo::yahoo:
AND alwaysFlOoReD ALWAYS I TAKE A LOT OF TIME TO FINISH MY PROJECTS :icon_confused::icon_confused:
scotts90ranger THANKS FOR THE OFFER,I THINK I GO START TO LOOKING FOR A ROUND TOOTH GEARS HERE,BECAUSE ALREADY HAVE THE BELT AND ONE GEAR :icon_thumby::icon_thumby:
MastuhWaffles
11/2014 OTOTM Winner
OTOTM Winner
69
Texas
Engine Type
4.0L SOHC
2WD / 4WD
2WD
I need more sleep.
As Jeremy Clarkson would say about this... POWWWWWWWWWWWWWWWWAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHH
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
I CHECK ALL MY INJECTORS AND 2 ARE NOT WORKING :icon_confused::icon_confused: ,BUT THANKS I HAVE 10 I DONT NEED TO WORRY,I CLEAN 8 AND I PUT THE 4 IN THE RAIL INJECTOR,I PLAY WITH THE TIP OF THE NEEDLE(I DONT KNOW THE NAME LOL)AND ONE WORK AND THE OTHER IS COMPLETE DEATH :bawling::bawling: ,A FRIEND HAVE A ULTRASONIC CLEANER I GO TO TAKE TO THE SHOP IF THE INJECTOR GET BACK TO THE LIFE :yahoo::yahoo:
AND THE RAIL OF INJECTOR LOOK LIKE THIS,THE INJECTORS ARE CLEAN :( ,BUT I FINISH THE INJECTOR CLEANER FOR CLEAN VERY WELL THE OUTSIDE RAIL OF INJECTORS :sad::sad:
AND I USE THAT SISTEM FOR CLEANING MY INJECTORS IN HOME
http://www.youtube.com/watch?v=7aT4S1lIBAY
BUT THE BROWN TOP DONT FIT INSIDE OF THE SYRINGE :( ,BUT I MAKE WORK,NOW I NEED TO READ AGAIN THE POST FROM STINGER AND RE-PIN MY COMPUTER TO MAKE IT WORK WITH THE AUTO WIRE HARNESS FROM MUSTANG,AND I WANT FINISH BEFIRE THIS YEAR TO START THIS ENGINE,BECAUSE I AM TIRED TO TAKE MY DAUGTHER TO THE SCHOOL IN MY MOTORCYCLE IN THE MORNING WHEN IS RAINING OR REALLY COLD :annoyed::annoyed:
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
I DONT HAVE KIDS TODAY AT HOME,SO I TAKE MY WIRE HARNESS OUT FOR CHECKING SOME PLUGS,AND I FOUND IS NOT FROM A 93 :icon_rofl::icon_rofl: ,I REMOVE THE WIRE HARNESS FROM A MUSTANG AND I THINK MAYBE FROM A 91? :D:D
THE 93 DONT HAVE A DISTRIBUTOR RIGHT? HAVE COIL PACKS?
VICTORHUGO
TIJUANA MEXICO,
FORD
3.0 STOCK
THE BEGINNING OF THE FUN :icon_rofl::icon_rofl:
MY WIRE HARNESS WAS FROM A MUSTANG LOL,BUT I DONT REMEMBER THE YEAR I THINK FROM 90,BECAUSE HAVE A DISTRIBUTOR,AND I FOLLOW THE INSTRUCTIONS FROM STINGER.PERFORMANCE ;) AND THEY SUGGEST TO USE THE EGR CONECCTIONS TO CONECT THE VAF ;) AND FINALLY FOUND THE PLUG ;)
ORANGE AND WHITE STRIPE IS 5 VOLT REF
BROWN AND LIGHT GREEN STRIP IS VANE AIR FLOW
BLACK AND WHITE STRIPE IS SIGNAL RETURN ;)
THE BROWN AND LIGHT GREEN I CUT IN SOME PART OF THE WIRE HARNESS I CHECK CONTINUITY WITH MY VOLTMETER AND I DONT HAVE CONTINUITY,I NEED TO TRACK THAT
AND HERE IS MY VAF FROM BMW :D:D
I HAVE 14 DAYS LEFT TO START IN A BENCH THAT ENGINE :icon_surprised::icon_surprised:
Staff online
Kirby N.
March Truck of The Month
