4r55e or similar trans rebuild question
Rangerin503
I have a 1996 4.0 4x4 Ranger, and decided to give rebuilding the automatic transmission a go myself. I finished all of the internals and valve body without really inspecting the inside of the case. There's some gouges around the holes where the adjustment bolts are located, and I don't know where to go from here. Can I file them out or do I need to find a new case? If I need a new case will any of the 4r or 5r ones work or do I need another 4r55e?
Sent from my XT1635-01 using Tapatalk
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
That’s the way they are. I always try to remove any pieces of flash that looks like it’s ready to break off.
Rangerin503
Thanks. That's the answer I was hoping for. Now to put it all back together and pray that it works.
Transman304
43
Morgantown WV
Chrysler PT
2.4
Good luck, got any questions while doing the overhaul just ask. Lot of members on here with great tips and tricks on doing this.
