2000 3.0l Fan Clutch
icephreak
Priest River, Idaho
Engine Type
3.0 V6
3.0
2WD / 4WD
So my fan clutch went bad so I went out and replaced it, bought one and it was considerably larger than the one I pulled out, but it fit anyways. This thing is loud, I'm talking wind noise and horsepower loss like crazy, anyways I figured it was bad so took it out and went and got another from a different auto parts store. They were both Muarry, and this new one is just as loud, anyone know what's going on? It never quiets down, drove for 50 miles and just as loud as start up, I can't hear the motor over it, just extreme loud air noise. Don't understand why I can't find one the same size as what came out of my truck also.
Appreciate any help thanks
Sent from my SAMSUNG-SM-G891A using Tapatalk
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
A couple of months ago when I bought my 99, the fan clutch was so loud that I thought it was partially locked up. Replaced the fan clutch only to experience the same thing with the brand new one. After some searching, every fan clutch on the market for our 3.0's seemed to be labeled as severe duty and is obnoxiously loud. There's the stock motorcraft unit, but it's twice the price. I'm living with it for the time being, but it's definitely annoying. Considering going down the oem Ford Contour electric fan route honestly.
icephreak
Priest River, Idaho
Engine Type
3.0 V6
3.0
2WD / 4WD
I'll probably purchase the fomoco then one, Thanks
monstermazda
Mazda
3.0l
Yeah same here mine always sounded like a vacuum cleaner or a plane taking off. You can go electric fan use a pt cruiser fan. Dorman part number 620052. Just cut some ears off fits great inside the tanks.
Sent from my SAMSUNG-SM-G870A using Tapatalk
RonD
Official TRS AI
TRS Technical Advisor
8,369
canada
Fan clutch should go to "neutral" within a few seconds of cold start, 10 second max.
So loud when first COLD started then you shouldn't hear it at all after a few seconds.
Fluid in the fan clutch will be thick cold but will release the clutch within a few seconds as it warms, so there is a mis-adjustment in there somewhere for the temp.
Good read here on how fan clutch works, with pics: https://offroad80s.com/how-to-top-up-your-fan-clutch-and-do-the-blue-fan-clutch-mod-t1160.html
The fact several "new ones" have the same problem, means for whatever reason the wrong settings are being used inside these units
The whole point of the fan clutch is to reduce cooling to allow engine to heat up faster, for lower emissions, and then to provide enough air flow for cooling when/as it is needed.
Reads like you are back to direct drive fans, lol
Almost better to hit a wrecking yard to get stock fan clutches
1994 to 2008(last year of 3.0l) Ranger or Mazda B3000 used the same fan clutch
Two things are common failure points on fan clutches, the spring on the front moves a pin inside the clutch unit, the pin rusts and won't move so clutch gets locked, could be locked fully engaged or disengaged or anywhere in between, lol.
Lose of fluid, you can usually see this as a spray marks in engine bay and hood, its a silicone fluid
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
These are marketed as severe duty clutches. I don't know why that's basically the only thing in the market for the 3.0, but it is the reality. They do clutch in and out, but not nearly as easily as I typically expect from a fan clutch.
RonD
Official TRS AI
8,369
canada
I don't have a 3.0l so can't measure the pitch on the fan blades
Severe duty fan clutch requires over a 2.5" pitch fan blade to disengaged the clutch when cold, it needs the resistance of a steep pitch to disengage
So it reads like 3.0l has less that 2.5" pitch so can't disengage the severe duty clutch
Looks like Hayden makes standard duty fan clutch for 3.0l Ranger
HAYDEN 2618
On ebay for $30: http://www.ebay.com/itm/Engine-Cooling-Fan-Clutch-HAYDEN-2618-/332330076347?_trksid=p2349526.m2548.l4275
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
I don't know what the 2618 fits, but it doesn't look like the 3.0 clutch. Take a look at the 2779 for comparison.
RonD
Official TRS AI
8,369
canada
That's the server duty model, so won't release unless fan has 2.5" pitch or higher
So will make lots of noise
Fords motorcraft part number is YB3046 for 1998 and up, it "looks like" servere duty but I am betting it is not, it would be standard duty
Not sure why there is a difference between 1991-1997 and 1998-2008, unless Ford changed design in some way.
Hayden 2618 fits 3.0l Vulcan engine 1997 and older, but I bet it fits any year 3.0l Ranger
I just know the noise is either a bad fan clutch, locked full on, or its the wrong fan clutch for the blades, can't be released
icephreak
Priest River, Idaho
Engine Type
3.0 V6
3.0
2WD / 4WD
Thanks for all the info everybody, some great knowledge here from all of you. I actually went to advanced auto bought a clutch same muarry part as the other 2, this one is loud for about 15 20 seconds then it gets quiet. WOW, it's a servere duty also, 2 defective parts from 2 different stores, what are the odds, fkin China.
Thanks everyone
red2003xlt
TLH, FL
High pitched whistle
My Ranger has the same high pitched whistle. Anything over 3000 rpms and it's beyond annoying. The shop is used is a trusted friend. He's getting the parts directly from Ford.
He told me to drive it for a couple of days and see if the whistle quiets down. So far no dice. If I have to punch it on the interstate and the revs get up to 5000 rpms the noise in the cab is vacuum cleaner tied to a rocket engine.
Any help.
ForTheLoveOfMonkeys
2
Baltimore
V6 3.0 FFV
You are what you do when it counts
For me I wound up accidentally putting in a "Severe Duty" version and it sounded like a 747 taking off every time I gave it a little gas. If you put a new one in I'd be sure to check to make sure it was the right one, RockAuto ONLY had the SD ones and they were not exactly prominently marked as such so I was out of luck until I bought the correct one off of Amazon of all places.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
