Burnside
- Sep 11, 2007
- Reaction score
- 0
- Age
- 39
- Location
- Sparland IL.
- Make / Model
- Ford
Hey guys I need clarification.
I need help bleeding the m5od after replacing the slave cylinder.
I have searched and read all of the different methods to bleeding the clutch, and I've actually done this once before successfully. Last time simply hanging the reservoir upside down seemed to do the trick.
This time I've pumped about 1/2 gallon of fluid through the dang thing and can't get it bled. I've had the master cylinder removed from the firewall, turned upside down, and pumped it until you can't pump it with your hand, its rock hard. But once installed on the truck again it does feel soft with your leg and it still won't go into gears. It is visible moving the pressure plate a decent amount.
Does anyone have pictures or a better explanation of "inverting the master cylinder"? I have not had the master cylinder below the level of the slave cylinder yet. I simply had the reservoir and master pulled to the wheel well region and turned the master cylinder upside down and pumped. I've done this more than once with no improved results. Does the reservoir need to be lower than the master when performing this?
Could I possibly have a leak past the master? I've thought that but am more inclined to think I do not have all the air out of the system as it is a known whore.
Some folks on here reply to these posts with, oh it's pie- just gotta invert it is all. If you have it down to a science please explain exactly how you hold your tongue during this procedure, it's owning me. How low do you hold different components, etc. maybe I will do a write up with pics on this if I can get it to bleed. It seems to have stumped a lot of people.
I couldn't get the quick disconnect plugged into the new slave for the life of me until I opened the bleeder, relieved the pressure, read that on here, that should be in the write up too.
P.S. I do not have a clutch reservoir diaphram, this truck has never had one and has ran with no clutch issues for several years. What is the real purpose of the missing diaphram and do I need to get one? are they the same as on full size clutch resevoirs?
Thanks, Josh.
Thanks, Josh.
