no balls
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
Make it fast, Make it loud.
hey guys, my new '90 ranger 2.9 i just picked up has no power whats so ever. on the highway up a slight hill floored in 5th gear at 60ish i loose speed and i barely hold it in fourth. on start up it seems to pop and chock for a few seconds until it settles out and idles fine koeo fuel pressure is solid at 38 for well over a minuet, i checked the timing and its at about 10* btc but i now realize that the SPOUT was definitely plugged in, but at idle, not adjusting it, shouldn't it not really matter..? i havent pulled the codes as of yet. any help would be great guys
2trux
16
Albuquerque NM
Ranger
2.9 L
Recheck the timing with the spout removed. Even at idle it advances the timing significantly.
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
okay i will and ill post results
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Yes, check timing with SPOUT disabled
How many miles on the engine?
Might be worth while to do a compression test, compression is directly related to power.
Not sure if the '90 non-calif. 2.9l will have an EGR system, these actually add power if working correctly, they allow more spark advance without knocking/pinging on regular gas, but can rob power if not working correctly.
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
well dash sayd 8000 so 108,000? 208,000 maybr, though it looks too nice of shape to be 208
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
am i supossed to pull the wires off of the icm? or if there a harness somewhere further down the line?
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
wait, its that little grey block, isnt it?
RonD
Official TRS AI
8,370
canada
No, there is a two wire connector with a slide in contact, you pull out this contact to disable SPOUT connection.
Picture in #5 post here: http://www.therangerstation.com/forums/showthread.php?t=132369
And #2 post here: http://www.fordrangerforum.com/2-9-liter-tech/93749-1988-ranger-timing.html
The connector in #5 is shown laying on the TFI module, that is just for the picture, it is on that wiring harness but not necessarily at that location, the slide in plastic connector can be black or grey, and usually the wires are yellow.
EDIT:
Opps, you posted while I was typing, yes, it is that grey block
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
haha yeah i figured as much, if the timing isnt it, any other ideas?
RonD
Official TRS AI
8,370
canada
If it was at 10 BTDC with SPOUT working then part of your problem will be the timing.
Get that set and then see what improvement there is.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Advance your timing to 12-15*.
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
what was the timing at?
what does the vacuum gauge do?
what do the spark plugs loo like?
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
the timing was at like 8*
at idle im at like 12 lbs of vacuum
aaaand i honestly havent had time to pull them off
nesralyrrej
2
Arvada Crawlarado
ford
4.0 s/c
i have also noticed fairly excessive fuel usage, a half tank (down from full) got me about 110 miles.
im beginning to think its a clogged cat, thoughts?
Members online
Today's birthdays
Shran
April Truck of The Month
