T-block for parts store extended brake lines
SeanC
I'm trying to duplicate the front brake line setup detailed in the tech library here: http://www.therangerstation.com/tech_library/ReplacementBrakeLine_Front.shtml
I've googled for an hour, and I can't seem to locate a T-block with the proper configuration. It needs two 3/8"-24 female inputs, and one 3/8"-24 male output. The T-block in question is shown below.
Can anybody link me to a source for this part?
dzrt_ranger
SeanC
I didn't find one that already has a male 3/8" fitting on it but you could get this T fitting http://m.summitracing.com/parts/ear-972050erl?seid=srese1&gclid=CjwKEAiAtf6zBRDS0oCLrL37gFUSJACr2JYbmSf44eSSfzntCKRdyZiemDAh1rcuhAqtmy9_NVJMshoCouTw_wcB
And also get this adapter http://www.jegs.com/i/Russell/799/661520/10002/-1
And just screw it on to get what you want.
Thanks for the information. I considered a similar option, but I was worried about sealing problems with mating a brake line to a regular old NPT connector (no flared fitting). I assume you had no such issues?
dzrt_ranger
I've used those type of fitting to make myself custom lines and never had a problem when they're properly tightened
