radius arm bushing replacement
rochhound
arizona
i have a 1991 explorer the radius arm bushings are toast,when i hit the brakes the front end pops, ive looked through my books to find out the easiest way to replace looks the easiest is removing the crossover there held in. any ideas would be appreciated
thanks
cvar
19
Mazda
4.0L V6
Yup, easiest was to remove my crossmember. Grind off rivets, replace them with grade 8 bolts.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
ok so i have a 92 and it pops when i hit bumps and hit the brakes would that be my ra bushings or ball joints?
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Most likely radius arm bushing. You can usually tell if they're bad just by looking at them. This is what mine looked like before replacing them. Note the big chunk missing:
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Could also be a bad shock.
