Extended brake lines
rangerbum
30
Kalispell, Montana
2.8l
I have been on the hunt for an affordable alternative to the spendy and unreliable braided extended brake lines. I was able to find a page about extended brake lines(http://www.therangerstation.com/tech_library/ReplacementBrakeLine_Front.shtml), but found that it was lacking the year, model, or drivetrain of the vehicles these options work on.
The part numbers listed all have fitting sitting sizes of a 10mm banjo fitting on one end, and a 3/8-24 female fitting on the other.
When I looked up my truck(97 2wd Ranger) I found that my fittings are a .375 banjo fitting and 3/8-24 female. The factory hose length is 13.625".
I found that a 2002 Ford F-250 SD 2wd 5.8efi has the same fittings. The passenger side hose is 20.25" and costs about $15 at AutoZone. So order two of them and for thirty bucks you'll have roughly 6.5" longer lines.
AutoZone part number 71061
SenorNoob
567
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
That looks like some good info. Have you actually tried it?
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,734
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Has anyone done this?
BlackBII
Ranger Custom
Truck of Month
982
UT
85_Ranger4x4
17,838
SW Iowa
2002 F-250 with a 5.8 is going to be a rare bird to track down parts for...
Junk Collector
Truck of Month
4,802
Rapid City SD
I used those GM brake lines for my D44 swap and they worked great.
Now what we really need is a longer brake line for the rear. Having one custom made is always an option but one off the shelf would be better.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
e350 lines with drop downs...18 in of travel no sweat.
best 10 min you can do.
