noahkenny
- Mar 14, 2010
- Reaction score
- 4
- Location
- Cullman, Alabama
1995
- Make / Model
- Ford
- Engine Size
- 2.3l
Hi guys, Have a 95 Ranger that when I bought it the interior lights would not go off. Turns out that problem was a stuck switch in the right door. Cleaned the switch and problems solved. Several weeks passed and now the right side blinker lights are on even with the switch off. You can pull fuse 27 which is the interior light fuse and they will go off but while driving when you turn on the right blinker the interior lights blink with the right blinker. It only happens with the right blinker. If you reinstall the interior light fuse then the right blinker lights stay on constantly and the right blinker does not work. The truck has not been wrecked. I have a factory wiring manual for this truck but cannot find any corrolation between the interior lights and the right blinker. I have searched the forums but have not came upon a solution. Any help would be apperciated.
