Tool
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Replacing the power steering pump and the SM calls for a power steering pulley removal tool T69L-10300-B. Any tricks.Manual doesn't go into detail about its use. The end of the pulley shaft is a Allen head. Is it a spline or threaded. Thanks Dirty
BlackBII
Ranger Custom
Truck of Month
982
UT
Is it neither; the pulley is pressed onto the shaft.
Here is the tool. By turning the end of the bolt and holding the nut with a wrench, it will pull the pulley off.
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
It's actually just a press fit. Rent the tool from the auto parts store it will remove and reinstall vthe the pully. The instructions make it sound way harder than it actually is.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
got the part number of that tool and where to get it at. Thanks
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
It's a standard tool. You can borrow it from the auto parts store or buy it from harbour freight for around 30 bucks
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Worked like a charm (OEM 27031). Got it at AZ for 40 bucks. It even had the installer. Thanks Dirty.
