BudgetB3000
- Jul 4, 2018
- Reaction score
- 0
- Location
- Pullman, WA
- Make / Model
- Mazda
My truck is a 1998 Mazda B3000 4x4 5-Speed. This leads me to believe that the transmission is an M5R1? I am a bit confused about the differences between the transmissions. Anyways The truck shifts perfectly when turned off, but when on it has difficulty shifting into 1st and reverse. It also is a bit difficult to shift in to 2nd and 3rd and it will usually "catch" (something to do with the synchros maybe?) and then slide into gear. I'm wondering if this could just be a slave cylinder issue as I have already replaced the master cylinder and bled it correctly. My fear is that the synchros are probably worn and then will need to be replaced. If that is the case would this kit be everything I need to get my transmission back in to working order? https://www.allstategear.com/M5R1-Bearing-Kit-with-Synchro-Rings-p/bk247aws.htm
Any help is appreciated,
Thanks!
Thanks!
