jeep dana 30 swap who's done it?
7
murphy north carolina
ford
2.8 v6
well im pretty locked on doing this swap if i can find a front axle. the dana 30 seems to be plenty strong with the right upgrades. i was thinking of just running 33s or 35s for now. does any one know what axle year i need to use coils? or should i do a leaf spring swap?
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
3.0
search button
7
ford
2.8 v6
and the reason for a dana 30 is i dont want full size axles..well not yet any ways i wanna keep it on the road for a while and i dont wanna have to get new rims and tires as soon as i put it in. im easy on the gas and from what ive read its just as strong as a dana 35 and thats all i really need. im going for front end flex i have tons of rear flex and no front. i just dont see much flex in a ttb set up unless i put a expensive custom lift kit in.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
The best D30 ('95-'99 XJ) is still a hair under that of the D35, mainly due to the smaller R&P gears (I've seen them strip teeth on occasion). 33s should be fine on it, but I'd be hesitant to use anything bigger with it under an RBV (yeah I know Jeep guys run 35s on it all the time, Jeeps are also lighter up front). There are at least a few D30s in use under RBVs however. I'd suggest looking in the RBVs Under Construction section, I recall see at least one right near the top there just recently.
I've got maybe $700 into mine... Not exactly "expensive" (you'll usually blow past that with a SAS), however no doubt it is pretty custom (at least in application of parts used, not so much the parts themselves... Most are available for purchase although I did make a lot of it myself such as the radius arms which kept the cost down somewhat).
Todd
HCT
OTOTM Winner
Solid Axle Swap
12
Troll land
BIITR
Engine Type
4.0
2WD / 4WD
Solid Axle Swap 4x4
The TTB can flex. I didnt have a lot of money into mine and was very happy with it.
Only reason I went strait 1 tons was the strength. I was starting to ask more of the 35 then what it could handle.
dangerranger83
5.0 HO under the hood!!!
Solid Axle Swap
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
I hope to be putting my D30 under my truck in the next few weeks, just got the rest of the stuff needed to get it started to be put under my truck.
BowTech99
South, Ga
1999 and 1998
Turbo 2.5L and 3.0L
Stay out the rocks with it and 36's are fine. Muds alot easier on parts.
Anything bigger than 33 in the rocks and not so good. Good axle, and plenty of aftermarket, just cost $$ to get one right.
#1greenranger
2
Omaha NE
4.0 v6
heres an 05 with a D30 5inch lift rocking 38 15.50's as a daily and beat to death on the trails and hasnt broke anything yet with rocking the38's for 30,000 miles
dangerranger83
Solid Axle Swap
54
Lafayette, IN
Just finished mine up about a month ago and love it. I have more then a grand into it due to I bought some of the best longarms I could find. Check out my build thread, link is i my sig. As for tires, I plan on 32s that I'm getting cheap but are new off a coworker plus rims.
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
16
Fort Wayne, IN
4.0, 5.0
check out my build thread. I really like how well it drives now after the swap. I would go coils if i was u, alot less fabrication.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
Solid Axle Swap
19
Farmington Il.
4.0
I did the swap on my 88 I am running 37's with moly axles. I have not had a problem yet and have pushed it harder and harder each time I have been out in it. I am running YJ springs in the front and I stuffed the passenger side so far that it took the fender off it's lower mount. Here are some pics and I'll see what I can do with getting some of the setup later.
mhughes165
Solid Axle Swap
9
302
hmm...idk, id just get a eb 44 if u can find one, its easier (bolt in) stronger and has alot more support for upgrades, i have comfortable run 40s locked with a eb 44 and molys
Staff online
Shran
April Truck of The Month
