Where do I find the oem forged 2.3 turbo pistons?
competitiveaudioman
I have searched ebay and other retailers for a set of oem 2.3 turbo forged pistons for my n/a 2.3 turbo build. Where do I find a set reasonably priced?
AllanD
TRS Technical Staff
TRS Technical Advisor
134
East-Central Pennsylvania
1987... sorta
'93 4.0
they've been unavailable for more than a decade.
Several manufacturers have offered customs from time to time
I'd suggest asking on the turboford forum
Sorry I don't have the URL...
4D55ranger
I have a 4d55(2.3 turbo diesel) I'm looking for a turbo.
Can anyone tell me where to get one?
Does a oil cooled turbo for 4d56 interchange?
turbo91xlt
RBV's on Boost
63
Goshen, NY
1992
have CP make you a set
turbo91xlt
RBV's on Boost
63
Goshen, NY
1992
or get a used oem set, plenty of people have gone that route
DCinDC
20
Northern VA
You do not need forged pistons. Depending on the year of your N/A engine you may not need to change them. I know for a fact, from my own experience, that 93 ranger hypereutectic pistons will stand up to plenty of boost. These would be a higher compression which is what you want anyway.
You should tell us what year engine you are working with.
redhurricane
RBV's on Boost
3
Westminster, Colorado
2.3
Please elaborate on why you'd want a higher compression ratio in a turbo application.
DCinDC
20
Northern VA
For more power and better drivability, obviously.
This whole turbo = low compression line is BS.
My 93 Ranger had 9.4:1 compression. It was stock. I ran 18 psi on it for a long time.
On Merkur XR4tis one of the BEST mods is to raise the compression.
I was assuming that this guy has an older non dual plug head 2.3 engine. That would be 9:1. With a dual plug head and those later hyper pistons it would be 9.4:1. Any stock 2.3 turbo engine would only have 8:1.
"The one thing the Merkur XR4ti needs is more compression", Jack Roush.
But the number one reason to want higher compression is that I've done it and it works, and it costs less. Listen to those who have done things successfully. Not those who parrot what other talking heads on the internet say.
DCinDC
20
Northern VA
direct quote from that page:
Generally, compression ratio should be set as high as feasible without encountering detonation at the maximum load condition. Compression ratio that is too low will result in an engine that is a bit sluggish in off-boost operation.
redhurricane
RBV's on Boost
3
2.3
Understood. there are MANY factors that have to be considered in keeping AFR/detonation in check, making the blanket statement that more compression is better is not the answer. While you may have had success with your hypereutectic stock pistons at 18psi that does not mean that it is the "optimal" route to go.
Kudos to you for having hypereutectic pistons that lasted on a higher than originally engineered compression ratio/turbo application. My personal preference is to build it right, and build it once.
DCinDC
20
Northern VA
You're arguing against a forum member with experience in this very area.
I'm assuming that you don't have experience at building higher than stock compression ratio turbo engines. I do. And I've done it way more than once.
But you are also contradicting Jack Roush. And for what? To PARROT what others who also HAVEN'T DONE IT, say?
Why don't you add something to the thread and tell the OP where to buy some OEM pistons that are no longer available.
Or you can offer a real world, economical alternative. Like I did.
redhurricane
RBV's on Boost
3
2.3
In looking back at some of your previous posts on this subject, I can see that I am no match for your knowledge and experience. Your proven track record with hypereutectic pistons surviving 18psi shall completely negate the laws of physics.
I am pretty sure I offered an alternative to the original question, in forged 2.3 pistons. I got half way there, didn't include the "OEM" part. You offered hypereutectic pistons, which are not forged. I suppose we both got part way there, wouldn't you say? Since the OP hasn't even responded to this thread for a few months, and his previous posts date back to 2010 I would say you and I are having a spectacular internet argument.
SO what oil should I run in my turbo 2.3?
Really, no response is necessary.
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
