Radius arm removal help
welderman85
Hello I'm rebuilding my 1995 Dana 35. I'm currently trying to pull the third member out and found out I have to pull the driver side radius arm out. I have the knuckles pulled and the shafts out. My questions are it's supported with stands on the frame can I put a jack under the driver side ttb to hold pressure the undo the shock to release pressure off the spring to pull it out . Also any other pointers for pulling an arm
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,352
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
That's how I pulled mine. Truck supported on jack stands. Put hydraulic jack under radius arm, supporting it. Removed nut from top of shock. Eased everything down with the jack.
It took a good impact to break loose the bolt on the bottom of the radius arm/axle beam connection.
Ewgoetz
Venice, Florida
4.0
I did the same here as well when I was replacing all the bushings back in January.
Will
Forum Staff Member
514
Gnaw Bone, Indiana
Toyota
4.0
You have to remove the radius arm to get the carrier out? That pinch bolt won't clear stock radius arms, will it? That's a good case for getting a lift kit.
Didn't have to pull the knuckles to get the shafts out. Just the spindles. But while you have the carrier housing out, you can make life easier in the future by taking off that little e-clip that retains the right-side shaft and using a spring. Check out the picture near the end of this article.
http://www.therangerstation.com/how-to/suspension-and-body-lifts/maximum-flex-for-the-ttb-with-jeep-coils/
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,536
SW Iowa
Engine Type
V8
5.0
4x4junkie
Forum Staff Member
580
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
You may be able to get that bolt out by grinding one side of the head flat so it is "D" shaped, allowing it to be wiggled out (or in) past the radius arm.
Staff online
Today's birthdays
Kirby N.
March Truck of The Month
