7.5 to 8.8 driveshaft question?
Trucker mike
North Wilkesboro NC
2.9 then to 3.9 4bt Cummins
I'm upgrading to a 8.8 from a 7.5 in my 1986 STX ranger.
The axle with springs came from a 1998 explorer and I got the one piece driveshaft and my ranger has a tow piece.
Can anyone tell me how much do I have to shorten my driveshaft? Or can can I switch to the one piece driveshaft.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
What year vehicle did you get the one-piece shaft out of?
The axle flange should be in pretty much the same spot, maybe try holding it up next to it? I know that might be cumbersome, would be easier with a friend to lend a hand.
Trucker mike
North Wilkesboro NC
Axle, springs, drive shaft and disk brakes came from a 98 explorer.
What transmission do you have?
If you have any of the stock manual transmissions from 86 it will be about 2 inches.
If you have an A4LD you should be good to go.
85_Ranger4x4
17,837
SW Iowa
I did nothing for my driveshaft length when I swapped from a 7.5 to an ex 8.8.
I did have to drill and tap holes for the smaller flange bolt pattern in the pinion flange though.
