cp2295
- Jul 25, 2013
- Reaction score
- 7
- Location
- Washougal, wa
- Make / Model
- Ford
- Engine Size
- 4.0L swap, 8.8 explorer axle, IFS front end
- My credo
- If you ain't first you're last
My compression is between 130 and 140 in all cylinders, so that's good. However the vacuum is at 15-16" hg at idle.. I know it should be between 18-22 (unless these engines have low vacuum?).. The needle would fluctuate as the idle did. My truck idles kinda bad.. Just bounces around about 50 rpms is all though, so not that bad.. Can anyone tell me why it's got low vacuum?
