Manual rebuild, now no 5th gear
Rowesouth
Georgia
97 Ranger XLT, 4.0 engine, M5oD trans.
Did complete drivetrain overhaul a month ago, all went fairly well except now fifth gear won't stay engaged. Had trans all apart, replaced bearings & syncs; reassembly went well, all shifting seemed fine.
Get it all back in the truck and first road test i have reverse and 2st four forward gears. But 5th pops out of gear. Shifter seems to go all the way (and it looked engaged when i was assembling), but as soon as i let the clutch out it pops back to neutral.
I'm guessing I've got something in backwards or an adjustment is out of line. Before i tar it back apart, i'm hoping for a bit of advice on what to look for.
Any suggestions?
Thanks!
Junk Collector
Truck of Month
4,789
Rapid City SD
Worn out 5th/reverse shift fork would be my guess.
BlackBII
Ranger Custom
Truck of Month
982
UT
Shift fork or possibly the lock ball on the shift rail. See parts 16, 17 and 18 in this diagram
Renegade Jeeper
Riverside, CA
Any suggestions?
Thanks!
I know it's been a few years, but did you ever figure this out? I have a 2002 Ranger 2.3L that's doing the same thing after a rebuild. Pulled it back our and everything appears to be fine, and I can even spin the input shaft by hand without it popping out of 5th or binding.
