Rear Main seal / Lower oil pan drama...
geofri
Ranger
I am stuck bouncing between two mechanics right now and wishing I just took a week off work, bought more tools and figured out how to do it myself..
Anyway, If I can get a quick answer it may help me sleep tonight. Tomorrow morning a mechanic is re-replacing this rear main seal.
Short version and what prompted the thread - How poor was this installation?
I am violently opposed to how this looks. Do you think it would leak?
Looks fairly dry on the top side where this roll/kink is but I don't know that mechanic didn't wipe it dry before I got there and it had sat all afternoon and maybe oil drained down below.
Long/full story and more photos to follow..
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
It's rolled and dry, it is going to leak.
Some of the teflon coated seals, like Fel-Pro's, tell you to install them dry, which is fine if that's how the seal maker says to do it, but that is definitely rolled. Rolling can pop the spring off, which will make it leak
You kind of have to turn them as you put them on, if they don't have an install sleeve. Almost like starting a nut. That keeps the lip from rolling under.
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
What adsm said , that thing is going to leak like a sob .
geofri
Ranger
Thanks for the fast response! Makes me a bit sick to my stomach, as I am believing the quality of his work and basic knowledge may just be lacking and I think this project is beyond his skill set.
Untrimmed cable ties, a rag forgotten in my engine bay, sloppy caulking skills, then seeing the flipped over lip on the seal really "triggered" me..
I brought my truck to "Mr. Hernandez" who a neighbor had recommended after my mechanic " Mr. Nguyen" wanted $2300 for the transmission rebuild. Mr. Hernandez did it for $1800. ( yes, again proven, you get what you pay for).
He removed and then reinstalled my rebuilt transmission, while it was out, he noted oil leaking and suggested a new rear main.
I was not happy it needed replaced at less than a year old*, but now was the time to do it even if for insurance only i figured. Paid him $70 for that extra work.
*Mr. Nguyen had replaced Rear Main Seal, Lower Oilpan Gasket, and Valve Cover Gasket a year ago, and 6 months ago redid the valve cover gasket due to lingering leak issues.. they had slowed to the point I just ignored it and kept oil topped off, but not bad enough to take back to mechanic.
Mr. Hernandez saw the RMS was orange, and claimed Mr. Nguyen must have lied about changing it since it was still factory. ( does not feel like an old seal, quite pliable).
He said it also looked like they didn't change the "u-gasket" in the lower oil pan, so he lathered on some sloppy RTV for extra measure since there was oil showing there. He said he probably only changed the top peice, and not the part where he "Gooped" ( is it not one single peice of gasket??!! besides, how the heck could you get in to change part, and not all if it was 2 peices??)
New RMS installed and goop slapped on the outside of the (supposed) leaking area.
geofri
Ranger
These pics aren't opening. Is it just me?
Darn it.. photobucket is being wonky. I'm trying to figure it out.. Looks like they now have limited or only paid memebrship 3rd party hosting.
Rearanger
23
Southeast USA
Yes, had the same problem on another forum. You'll need to find another picture hosting site. My old PB pics are still showing but I hardly have any in PB. Seems it's only affecting larger users.
cbxer55
767
Midwest City, Oklahoma
3.0
You have to pay FailBucket $400 bucks a year for their extortion racket, if you want to host pictures there.
You can post pictures here that are stored in your computer. Scroll down when in the post screen and you will see a block that says Manage Attachments. When you click that, just follow through with everything.
I'll attach a pic here for your enjoyment.
Rearanger
23
Southeast USA
Does that mean you have to have your computer on for people to see the pic or is the attachment stored on the TRS server?
geofri
Ranger
Thanks for the photo tip. I have to edit each one due to size reconstructions.
Livid.
Mechanic warned me that my driveshaft ujoint was bad and making sounds( wasn't before...)
Got halfway home( 1mile) from picking up the truck and hear it when I slowed down to listen....
See attached..
cbxer55
767
3.0
Your computer doesn't have to be on. I guess it's stored, however that is done. I've put numerous pics on many sites, and with my home computer off, I can see the pics on a computer at work.
Another thing, if you are editing a post, you click "Go Advanced" and follow the same procedure.
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
