ox1969
- Jan 28, 2016
- Reaction score
- 0
- Make / Model
- Ford
- Engine Size
- 2.9
- Manual
So here is the back story. Bronco would intermittently cut out while driving like it was starving for fuel, then would start running fine in about 20 seconds. Changed the fuel pump relay, and installed a new harness. Wired the harness incorrectly and popped a fuse-able link. Rewired harness, and replaced link.
Now when I start the truck it is running really rich, so I swapped out the computer with a new one thinking I may have smoked it when I wired the relay incorrectly. New computer, still doing the same thing. I have also put in a new MAP sensor, better but still running rich. I used a computer for an 88 Bronco II, manual trans so matches my specs. Disconnected and plugged vacuum lines for the EGR system as well.
Also checked fuel pressure, 40 psi KOEO, and 35 PSI KOER. Has been sitting for about 2 hours and still holding 40 PSI. So assuming the fuel pump system is fine.
Have not checked the temp sensor yet, but was working fine before I wired the fuel pump relay incorrectly. Potentially could have shorted it, but not sure.
Have checked all vacuum lines for leaks, and checked grounds for the computer, all good.
Sorry for the long explanation, just wanted to explain what I have done up to this point and that it was running fine other than the intermittent stalling out, until I screwed it up some how lol.
Thanks for the help in advance.
