4.0 ltr V6 valve adjustment
Chines
Hi new member I got a 1995 Ford ranger V6 OHV and I can't find any numbers to set my valves so does anyone know what I have to set them too
Thanks for the help
8,370
Welcome to TRS :)
There is no adjustments on rocker arms for valve lash on 4.0l OHV engines
If you have ticking noise then lifter is most likely issue
Chines
Thanks i just got my block back and all the other stuff to put it back together just couldn't find any info on it there is new lifters all the way so hopefully no noise now
truckerdawg
5
GA via NC Mtns.
4"
31X10.50
New rocker arms I hope. Check the length of your pushrods and ends for scoring..
gaz
656
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
Chines:
This is a fabulous opportunity to bore out your valve train oil passage holes. Could just go up one size and experience an incredible improvement in top end oiling potential .)
