V8 swap questions
Jrp79
Mazda
I have a 94 mazda b3000 5speed.I got a 88 f150 with a 302 5speed with intentions on swapping the 302 and m5od2 into the b3000.
Can I use the stock 302 oil pan or would I have to get a dual sump?
And would it be hard to swap the f150 efi into the b3000?
Also instead of buying swap plates I plan on making my own with 1/4 steel but would it be wise to keep the f150 mounts.
8,367
Welcome to TRS :)
Good reads here on V8 conversions: http://www.therangerstation.com/tech_library/index-conversions.shtml
I think the reason the Explorer V8 was the better choice was because of the intake and other bolt-ons for the 302(5.0l).
Explorer engine bay is closer in size to Ranger, F150 is larger so bolt-ons can stick out farther.
I would do some measuring to see if a body lift is needed.
There were several versions of "stock" 302 oil pans :) , front sump, dual sump and rear sump
Rear sump will usually fit 2WD, not sure what your '88 will have
manual trans EEC-IV computer('88) would work fine in Ranger that had EEC-IV computer, in 1995 Rangers got newer EEC-V computers
85_Ranger4x4
17,753
SW Iowa
The dual inlet F-150 intake system is too tall to practically fit in a RBV.
The Explorer is a nice setup if you want, basically a cast aluminum Cobra intake. But if you are on the cheap a standard intake or an HO off a Mustang would work too.
If you find an Explorer to rob the intake off of the timing cover, harmonic balancer and accessory brackets/accessories are the most compact ones Ford made. If you go that route I can get you a link about how to make it work in a first gen.
I have a dual sump off like a Mustang. By stock I would assume you are refering the F-150 pan... most guys run the dual sump. Not out much if you have a slow day and want to try it though. In my case I think a front sump would have fit the best... but wouldn't work with the Explorer belt system.
That said I have done no EFI wiring.
I would just use the V6 mounts. I know 2.8/2.9/4.0 mounts work well I would assume the 3.0 mounts would be similar. I am going to swap back to that style of mount sometime when I get a chance, I am not happy with the Mustang mounts.
And the biggest thing to remember about this is every swap is different. What works for someone else may or may not work for you.
