big ass alternator?
motaaa
i have a 90 amp alt on my 87 broncoii but when im running my offroad lights, headlights, and my electric fan, the alt cant keep up and it drains my battery.
i read this but im not really understanding what i can do with the 2.9
i want at least 130 amps, what kind of alt can i hook up to it? i can make new mounts if i need to..
AgPete139
09/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Original_Ranger84
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
The Explorer 130amp alternator won't work cause it uses serpentine belt pulley. but I am pretty sure i read somewhere an 80's GM 140amp alternator from a 350 will bolt right up to a 2.8L mount which should be the same as a 2.9L
motaaa
the problem is that the 2.8 engines used alternators with external regulators, and the 2.9 has internal.. so if i used a 80's GM alt i would have to rig up an external regulator somehow
anyone know how to do that?
dennis461
2
Waterford, South Jersey
1991
Jeep
3.0l
motaaa
Look here, an internal regulator replacement with v-belt pulley...
Call them up..
They stand by their lifetime warranty.
Pos a pic of your alternator.
No trade in required, so yours becomes an emergency spare.
http://www.db-starter-alternator.com/Items/ho-7749-11 200 amp-one wire black powder?sck=2227323&caSKU=ho-7749-11 200 amp-one wire black powder&caTitle=NEW Ford Truck Car 200 Amp High Output Alternator 1965-1992 7749
damn i wish i had $230..
is it at all possible to take apart my alternator, take the back half of the housing including the regulator, and put it on a high output externally regulated alt?
martin
26
St Bruno, Quebec
1991
ford
the gm alternater is internally regulated.
NMB2
July 2010 OTOTM Winner
OTOTM Winner
Solid Axle Swap
22
Cody, WY
5.0 V8
ive had the GM 1 wire conversion for almost 5yrs. It was ALMOST a direct bolt onto my 2.8 bracket. I just had to use washers for some spacers on the bottom pivot hole, and all i did was run the wire from the alternator to the starter solenoid.
motaaa
would it be a late 80's or what?
heres the problem: 2.8 engine has external regulator
2.9 has internal
NMB2
OTOTM Winner
Solid Axle Swap
22
Cody, WY
5.0 V8
I understand that. With the 2.8 You still have to keep the voltage regulator hooked up or you lose power to the truck, but with the 2.9 having internal stator and isolator means there is no regulator on the truck to bypass, Its still a bolt in swap. You just swap alternators and run a wire from your alternator to the battery or solenoid. I run the 1wire on my 88 Bronco II as well, I have for the last year and a half. i just left the stock plug hanging incase i ever needed to swap the stock style one back in.
motaaa
so i run a wire from the unregulated GM alternator straight to the battery?
NMB2
OTOTM Winner
Solid Axle Swap
22
Cody, WY
5.0 V8
the GM alternator isnt unregulated, its a 1wire internal regulated alternator. You run that SINGLE wire from the alternator to your battery positive or the solenoid.
NMB2
OTOTM Winner
Solid Axle Swap
22
Cody, WY
5.0 V8
ill take a picture of one of mine for you later so you can see.
NMB2
OTOTM Winner
Solid Axle Swap
22
Cody, WY
5.0 V8
here is the alternator
this is what you do with the wire.
vwa-la, you have power.
Hope this helps you!
Staff online
Today's birthdays
Mudtruggy
May Truck of The Month
