Vibration at 35 to 45 mph.
codered1300
Hi all, i was doing my normal inspection and noticed my carrier bearing rubber was in pretty bad shape, so i replace the bearing. After replacing it i got a real bad vibration so i figured i'd take the shaft and have it balanced incase i accidently did something to the shaft while replacing the C.B. i also had all new joints installed in it. Now that took all the vibration out except for the vibration at 35 to 40 m.p.h. It does it on acceration or deacceration. I checked on motoralldata for a T.S.B. but found none. Any helpor suggestions would be helpful. Oh yeah my truck is all stock with 145,000 miles. replaced shocks not long ago. I also have newer tires that i also had balanced.
almostclueless
3
ford
Just because a shop balanced the tires doesnt mean they did it right.
AgPete139
09/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
It probably didn't look this bad yet though...
Check to make sure you installed it correctly. Are you obsolutely sure you got the right part AND the model number? When I replaced the CB back in January @ 170,xxx miles, the guy @ Autozone ordered a CB for the ranger. There is actually an option #2 for the ranger, which was my specific application. It said on his screen "Bring part in for comparison."
Another is to double-check the carrier bearing connection to that crossmember on the frame. The 2 bolts (were they 12 mm?) need to be properly secured, or that vibration could occur. The seating on the driveshaft could also not be properly installed (not calling you incompetant, just check it).
The Haynes manual (IIRC) said to mark the driveshaft on the differential flange. I don't know why this would make a difference, but I marked it and put it back in the same place just to be sure. How does the slip yoke look (this really shouldnt be causing too much vibration either though)?
codered1300
I sent my shaft to a driveshaft shop and had them check it, (i know the guy) and they checked it and welded new weights on it so it was out of balance. I did replace the bolts that hold the CB down so i know there tight, as far as the right bearing, i also bought mine at autozone it waws the timken bearing i'm not sure of the p/n though. I guess thats my next option is to take the bearing back and try another one. Thanks for the response.
AgPete139
OTOTM Winner
Solid Axle Swap
61
Houston, TX
Engine Type
4.0L OHV
2WD / 4WD
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
I tried the P/N 6061 for $27.99. Seemed to fit perfectly...
You driveshaft was off THAT much? Glad you got it looked at...
codered1300
Hey Pete, by the looks of your rangers bottomside it looks as rusty as mine, they don't use salt in Huston do they?
oldmantruck
2
State College, PA
4.0
HI,
It sounds like the carrier bearing isn't centered properly. It only moves about 1/4" so you wouldn't think it would matter, but Mine vibrated like crazy when I first replaced my bearing. When I loosened it I found that it had slipped all the way to the passenger side when I tightened it up. So I held it centred and tryed again, The vibration was reduced, but still there, so I pulled it as hard left(drivers side) as I could and now it is back to like before I changed the bearing. there is still a slight vibration, so I don't know if I need to slot mine and move it more, or If I'm getting into tire vibration now. I was too lazy to pull the wheels and was out of time, but i was amazed at how sensitive the truck was to this adjustment. I'm going to look for a one piece and swap it out.
codered1300
HI,
Hey thanks for the info, i replaced the originial bolts with a bolt and nut, so maybe i did the same thing, i will be sure to try that. Thanks
Shotokan1509
CT
I need to replace my center carrier bearing this weekend, how does the shaft come out/go back through it? Does it need to be pressed?
codered1300
No it doesn't need pressed, just use a hammer to get it off and the center nut to draw it back on the shaft. Word of advise take something and mark everything so you put it back together the same way. I had to replace the 2 bolts with standard bolts and nuts that hold the C.B. to the crossmember.
Shotokan1509
CT
Thanks for the info, now the hard part is getting the mount off in the first place... nice and chunky from northeast winters.
dennis461
2
Waterford, South Jersey
1991
Jeep
3.0l
Anyone know which carrier bearing fits which models?
I'd like to get one before taking off the old to minimize down time.
I see two listed at most places,
DSSS211590-1X
Ford Rangers
Bearing I.D. = 1.188 inch
Center to Center of Bolt
c-c Holes = 6 inch
and this one
DSSS211431X
Ford Rangers
Bearing I.D. = 1.259 inch
c-c Holes = 6 inches
Downey
3
Muncy, PA
ford
4.0
check your drive shaft bolts mine worked loss and caused a hell of a vibration
Members online
Today's birthdays
Shran
April Truck of The Month
