'94 ranger rough idle
tom.mitchell88
Truck shakes and sputters when shifting down into first or when at idle. Once it even stalled out at cold start. I changed all 8 spark plugs and added STP fuel additive,because it sat for a while, and it stopped for a week but has now has started.
Sent from my SCH-I535 using Tapatalk
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Well , you ran through that tank of gas. When was this last tuneup and filter change ,etc?
FritzTKatt
4
Ohio
Switch the coil packs around, if it runs better or worse then that's at least part of your problem. Replace as necessary.
snake
4
canyon lake tx
3.5
IAC would be the first suspect, vacuum leak and/or fuel filter.
