chh
- Nov 3, 2010
- Reaction score
- 0
- Make / Model
- mazda
- Manual
Trying to bolt in the right knuckle after replacing upper and lower balljoints. In the image (right_new) you can see that the camber/caster adjusting sleave does not go in as far as the other side(left_Original). It is bottoming out on the balljoint.....
Now that I am writing this I wonder if tightening the pinch bolt will force the balljoint down allowing the adjusting sleeve to bottom out.
Advice?
Advice?
