agross91
- Mar 30, 2014
- Reaction score
- 0
- Make / Model
- Ford
1994 ford ranger 2.3 5 speed 127,xxx ok guys new here but not to the automotive world really looking some help on my daily driver as shes down and i cant commute which is a big deal heres the problem im having. the truck will fire up idle perfect rev up fine but if i try to go down the road up a slight hill or under load it will misfire jerk pretty bad and i will have to press in clutch and feather the throttle until i can get it back running ok to return to idle then it will idle perfect go down the road again it will start sputtering missing and try to die out like its starving for fuel or seems to me. now with that said its normally only taking off or under a load hill etc. ive changed fuel filter,maf,egr,dpfe,iac,egr vacuum solenoid,tps,o2,cat good new correct plugs wires,coil packs have been tested and switched with known good coils there are no vacuum leaks fuel pressure holds 36 idle never drops below fuel pump is only a year old compression good. personally im leaning towards dirty injector or injectors as its running lean this truck sat for about 7 years before it was bought and put back on the highway a couple years ago from a family friend and hasnt had any major issues ill be taking the upper intake off in the morning to check out the injectors and clean them and replace all intake gaskets but wanted a few insights before i do it all or any other ideas
