Tire clearance
Mike92STX
58
Zion,Illinois
I'm tired of checking and replacing wheel bearings. I bought the truck with 6" of frame lift 2or 3 " of body lift, cutout fenders with flares. I have 35x12.5x15 BFG KM2s the wheels are 15x8 and I measured the back space last week to be 3.5. It also has 2.5" spacers. I asked a tire and wheel sales guy and he said I can't get less back space unless they are special order. I checked the clearance with out the spacers and the tires rub some with wheels turned all the way.
I have torqued the outside spindle nut to as close to 200 ft lb as I can get ,wrench only goes to 140. My son found some smaller spacers on line and I'm considering them because I don't need 2.5" the other ones are 1.5". Any body have any better suggestions?
The truck is a 1992 STX,4.0 . I switched the front and back differentials from a 327 to 376 from a 93 junk yard so the back is 2" wider than it was before.
bigmark303
RI
4.0, 2.5
Its just the nature of the beast for the TTB front end wheel bearings and tires/offset so far from factory.
I kept the factory wheels and ran 33x10.50 and 35x10.50 tires just to avoid the extra stress on wheel bearings from extreme offset and wide tires. Didnt help much. With 33x10.50 I got away with a little more than with 35x10.50 but still ate wheel bearings in quick time.
SAS swap or drop in tire size and get closer to or a factory wheel again.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The problem is the spacers. As said, having the tire out that far is too much leverage for the bearings.
If the tires are rubbing w/o spacers, I'd say either trim the fenders a bit or swap down a size on the tires.
