jabird12000
- Oct 2, 2013
- Reaction score
- 0
- Make / Model
- ford
- Automatic
Have 2.9 1990 ranger that is running very rough. Just replaced head gaskets again after 2 weeks ago replacing one head. Was losing coolant into the crankcase. replaced one head, truck was running perfect then overheated one morning, even though the tempature guage was not showing an over heating condition. Did a complession check and the #3 cylinder showed no compression. Changed the head gaskets again hoping I did not have a cracked head again. Adjusted the rocker arms while I was in there to try and quieten a noisy lifter. Got rid of the lifter noise.
Truck started just fine once it was back together but is running rough, but does not feel like it has a dead cylinder. Also noticed a lot of blowback coming from the oil fillier tube on the valve cover. Removed the oil fill cap and can feel air blowing out of the tube.
