Spring eye bushing replacement
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
I'm sprinting to get the swap complete on the Ranger this week and trying to offload a couple of smaller tasks. Have any of you guys paid a shop to replace spring eye bushings? I've got a set of sport trac leaves I'd like to throw in while the bed is off but would love to skip the labor time of installing new bushings. Just curious what a shop might charge.
Dirtman
Former Middleweight Moss Fighting Champion
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
I poop in the furnace.
Probably going to pay an hours labor so anywhere from 75-100 bucks.
However I say do it youself, if you buy poly bushings they dont need to be pressed in so zero time to install. And I've always just burned the old rubber bushings out. 20 minutes with even a little propane torch is all it takes. Just hit them with the torch till the rubber catches fire and then let them burn. After a few minutes you can just poke them out with a screwdriver. clean they eyes with some scotchbrite then the new poly bushings just slide in. Simple job.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Tempting. If I can get my hands on a set of poly bushings quickly I might just do that. I burned out one of the rubber bushings on my existing springs today, then promptly blew up my largest c clamp trying to press in the new one.
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
Look up the part number you need at energy suspenions website then just buy them on amazon. Youll prolly have them by Tuesday lol.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
I've been trying to do just that. So far I've come up empty on any urethane options for an 02 Sport Trac.
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
Can you measure the I.D of the spring eye, width of the spring, and overall width of the oem bushing? Alot of times you dont buy them per specific vehicle but buy size alone.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
I can do that tomorrow and try to dig through a catalog. Thanks for the suggestion.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
For anybody who cares...
There's nothing in the ES catalog that directly fits the 2nd gen Explorer and 1st gen Explorer Sport Trac front leaf spring eye (RB237). Per some users over at Explorer Forum, you can use Energy Suspension part number 3.2125 for that purpose if you leave the original metal sleeve in place.
The rear spring eye is the same size as the Ranger's, so RB131 or equivalent will work there.
alwaysFlOoReD
Forum Staff Member
TRS Banner 2012-2015
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
2WD / 4WD
Which catalogue did you use? I need to find a bushing for a non spec application.
edit; ES = Energy Suspension
Online or paper?
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Energy suspension 3.2125 was perfect for the explorer front eye bushings. I burned out the rubber core, ground out the remaining rubber with a rotary rasp bit, then tapped the urethane pieces right in.
https://m.harborfreight.com/high-carbon-steel-rotary-rasp-set-10-pc-62694.html
Quick question on the rear eye bushings. Should I take these sleeves out?
This is what's going in. Slightly different than the stock bushing. https://www.truckspring.com/products/Rubber-Leaf-Spring-Bushing-Type-1__RB-131.aspx
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
The link doesn't work but its fine to leave the sleeve in place if the replacement bushings require it for proper fit. Just make sure you file down the burrs.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
I hit with a sanding wheel so no burrs, but it definitely doesn't appear to fit. I can't lay my hands on my calipers at the moment or I'd confirm inside and outside diameter.
Which link doesn't work?
Dirtman
13,326
41N 75W
Engine Type
2.3 (4 Cylinder)
2WD / 4WD
2WD
It's up there.
Total Drop
It's down there.
Round.
The link to the bushings isnt coming up for me. Poly bushings should never be press fit or fall right in. Some grease and hand pressure should be all it takes...
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Today's birthdays
Shran
April Truck of The Month
