- Aug 15, 2007
- Reaction score
- 46
- Location
- toenails of foothills NW of Atlanta
- Make / Model
- ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- lima bean
- Manual
- 2WD / 4WD
- 2WD
- My credo
- vertical and above ground
Before going to the effort of R&R'ing the belt, why not set the distributor timing to 10BTDC and see how it performs? There is a rectangular plug{SPOUT} on the loom of wires leading to the distributor from the drivers side inner fender. It can be removed, and stored for replacement when done. When the plug is removed, the timing is fixed at 10BTDC, or should be adjusted to that number. The distributor hold-down bolt is near the base of the distributor, on the front side. It will go through a bar that pushes on the distributor and the block. It jams the distributor from turning freely. Loosen that with a 14mm, I think, so you can rotate the complete distributor. With the engine warmed, start it up and check that the timing shows the notch in the crank pulley lines up with 10BTDC. If not, rotate the distributor so it does. Turn off the engine, and tighten the hold down. Re-start the engine and check that it hasn't moved. If OK, replace the jumper. The engine should run well, and develop normal power.
If that doesn't fix it, your cam timing might be off. To get the cam timed properly requires R&R the cam belt, at least enough to turn the cam one tooth in either direction.
Do that, and see if it responds. If it were me, I'd take a picture of the original mark from the web and place it near where the pointer used to exist. It should give a close enough image that you can line up the cam to the non-existent pointer. Just make it look like the picture using surrounding bits & pieces for clues.
Also, it would not hurt to check for cracked, broken or disconnected vacuum lines that may have gotten damaged or loose. That will definitely affect idle. The MAP sensor can do the same, making the idle terribly un-stable.
tom
tom
