If you had the dis out and moved it then you need to find TDC. It's best done by pulling the #1 plug then bumping the engine until you find compression, then use the timing pointer to set it to 10* BTDC.
After that, set the dis back in and use the marks near the blower motor to get the initial timing set. I usually set the rotor even at the first mark (going clockwise) and then drop the dis in, get it centered up between them, lock it down, and then get her fired up and set the timing with a light. Remember to unplug the SPOUT connector, it's by the intake's center runner, passenger side.
