4.0L Normal Operating Temperature
fastpitchfan
Not sure why my previous post didn't get any responses, but I'd really like to know the normal water temperature for a 94 Ranger 4.0L engine. I just had an aftermarket gauge installed and want to know if what mine is reading is normal.
Syko
Vancouver Island, BC, Canada
not sure about the 4.0l but my 2.9 usually sits around 160 with the outside temp around 0-15 C*
Wicked_Sludge
43
Westport, WA
3-point-GO
it depends on what temperature thermostat is installed...
shadetree
9
East Texas
Explorer Sport
Normal operating temperature for most engines today is 195*, give or take a couple.:)shady
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
OEM thermostat is 195 degrees.
Wicked_Sludge
43
Westport, WA
3-point-GO
mtnrgr, the factory gauges arent that consistant. you could warm two different rangers up to 200 degrees and one factory gauge would be on the "O" and one would be on the "N".
a real, mechanical water temp gauge is the only way to go for accurate engine coolant temp readings.
irishblessing
Guest
195 is regular mines a little lower unless its way out of that range you shouldnt worry
