- Oct 22, 2014
- Reaction score
- 16
- Location
- Albuquerque NM
- Make / Model
- Ranger
- Engine Size
- 2.9 L
Engine won't idle with Spout installed **Solved**
Hey all,I am having an odd problem with getting my rebuilt engine running correctly. After installing my engine I got it running and timed with the Spout plug out. It seemed to be idling OK at that point. After replacing the Spout the truck would not start. Take it back out and it starts up.
Things I have observed:
When idling the RPM fluctuates 800-1100 RPM
Seems to have an intermittent miss
Unplugging the IAC at idle kills engine.
Unplugging vacuum to MAP kills engine.
Unplugging air temp sensor in manifold kills engine.
I can plug in the Spout when the engine is running at 2000 RPM and I can see the timing advance, so that seems to be doing what I expect.
Thoughts in my head:
Valves not adjusted correctly. (Set to 1/2 turn, adjusted on stand)
Injectors not working correctly. (Cleaned, micro filter & o-rings replaced)
Spark plugs. (New less than 1000 miles ago)
Vacuum leak. (All new gaskets during rebuild)
I will buy a vacuum gauge & compression gauge tonight to see if there is any odd readings.
Is there any way to test the injectors? Pull the rail and turn key on and check for leaking? Crank engine and check for spray? (Is this even possible?)
Any other ideas for things to check?
Thanks
Thanks
