Inner tie rod end removal? without the special tool?
Stangman
4
Sardinia, Ohio
4.0L SOHC
I always thought there was a type of "Special" inner tie rod end removal tool out there that magically removed it for you and you could only get it from a tool truck (snap on, mac)
But I was googling around, and found a youtube video of a guy changing an inner, and it was nothing more than what appeared to be a home-made crows foot.
That being said, wouldnt a large adjustable wrench be suitable for this??
I had a small 4 wheeling mishap, and the only available place to be hooked to, to get pulled out (because BFG all terrains SUCK in mud!) was my sway bar on the passenger side. so needless to say, we broke the sway bar mount, lost the bushing, and the sway bar came in contact with my inner tie rod end and bent it. So a trip to the pull n pay tomorrow should reward me with the sway bar bracket, and maybe the bushing if my bushing is officially MIA out in the field. Then I was going to order an inner tie rod and sway bar link from Rock Auto.
So, if anyone has any insight on that tool or a suitable work around, I'd appreciate it.
88_Eddie
Solid Axle Swap
155
Raleigh, NC
2.9L, 4.0L
there is, it's called a pickle fork
you mean a pickle fork?
i'd say no
no, they suck everywhere
wait, you hooked a chain to a tie rod and had someone pull you out? you cant see me, but i'm facepalming myself right now......with both hands
get some sockets and a BFH. always start with a BFH, replace parts/tools as needed. good luck
Stangman
4
Sardinia, Ohio
4.0L SOHC
Please re-read my post. I was not pulled by my tie rod end. I was pulled by the sway bar. Only spot we could get too. I do not trust the chinsy tow hooks on the front. Seen too many FX4 tows go wrong w/ those.
Also, how would a pickle fork get the INNER tie rod off?
Reading>you j/k
And yes, I do agree, that do suck EVERYWHERE.
I want MT's.
Thank you, that might be a good investment for me, as I do a lot of work on cars. Never thought to try Harbor Freight.
legoms013
09/2013 OTOTM
OTOTM Winner
Solid Axle Swap
26
CA
4.0L V6
Please re-read my post. I was not pulled by my tie rod end. I was pulled by the sway bar. Only spot we could get too. I do not trust the chinsy tow hooks on the front. Seen too many FX4 tows go wrong w/ those. There is nothing else proper to hook to, so just get over the fact that you consider them cheesy, they are tow points and you would not be in the position you are in now had you used them in the first place.
Reading>you j/k
I want MT's.
That being said, you want a pickle fork or tie-rod separator. Its a two prong dealio with tapered prongs and is hammered in between the knuckle and the tie rod. I've used the one from Harbor Freight from the above link, it works good and for the price cannot be beat. $10.
This is what you want I believe: http://www.harborfreight.com/16-inch-tie-rod-separator-1759.html. Though your truck is a little newer than mine and I am not well versed with rack and pinion steering setups so double check with a few others before making a purchase. I know for sure that the tool I listed will work on the outer tie rod ends, at the knuckles.
I've alos tried hacking up a large wrench to make my own tool, but it takes too much work considering buying the correct tool is so cheap.:icon_thumby:
88_Eddie
Solid Axle Swap
155
Raleigh, NC
2.9L, 4.0L
Reading>you j/k
I want MT's.
lol, my bad man. i'm not gonna lie, i was drinking and TRSing last night, i was hammered when i wrote that. just disregard what i said.
kcm1582
Ford Technician
39
Worcester, MA
4.0
The pickle fork will pop the outer tie rod out of the knuckle but he needs to remove the inner which takes a tool like this:
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
TRS Banner 2012-2015
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
^^^^ Bingo. That's what you want for a 98+ truck with a steering rack.
doyouquaxu
26
Orange County CA
wait, inner (on the rack) or outer (connected to the knuckle)?
edit: if it's the one on the rack, i've used a monkey wrench, or a big crescent wrench. just depends on whats around. a buddy snapped one on his truck doing something similar, so we field fixed it with the tools i already mentioned. i don't see why a special tool is needed, as long as whatever you have can grab onto the base that screws into the rack.
if it's the one on the knuckle, take out the cotter pin and loosen the castle nut. if you cant pull it out on your own, get it so that the top of the nut is even with the end of the joint, protecting the threads. then use a hammer to tap on the castle nut until the joint pops loose.
no special tools needed!
Stangman
4
Sardinia, Ohio
4.0L SOHC
I dont know why almost everyone who reads this thinks of the outter tie rod end, lol
Oh, and since I'm payin on the truck still, I'd prefer to have mechanical damage rather than physical damage... mechanical is easier to fix! (although I do paint, I'd prefer not to!)
It's all good man, I suppose it's what I get for posting at 1am
THANK YOU! LOL
You must have done well in english class! :icon_cheers:
To all the others,
THIS TOOL DOES NOT WORK!!! It wouldnt fit over the knuckle section of the inner tie rod!!! What a joke! The area where it actually fits over the knuckle is NOT deep enough to fit in over the tie rod end. There was a good half inch before it would go on.
But yes, I luckily had an adjustable wrench, and a 5lb sledge and got the job done!
Now to get it to an alignment shop and get my wheel straight or see if there is any further damage
bilzy7
32
Lynn, MA
4.0 SOHC
Doux, you bang on the castle nut itself? I just hit the main metal whatever it's called that the whole assembly mounts to. Obviously it wouldn't matter if you damaged nut since all tie rod otters come with new castle nuts. I was so mad when my outer didn't come with a grease fitting. I got a multiple pack of like 7 grease fittings for 5 bucks and none fit correctly so I hammered one in. Screw it, it worked.
On the topic of inner tie rod end removal tools, I've seen some with ends that fit the crows feet, and some that are rounded off. Are all tools same size, you just need specific crows foot to attach to it correct? Bout to drop 78 bucks at sears on a good one with multiple crows feet so I just wanted to make sure before I have to play return for right one. I'm pretty sure they are all same size but looking online is hard to tell. They have numbers like 45750 and a 47500 ect.
bilzy7
32
Lynn, MA
4.0 SOHC
THANK YOU! LOL
To all the others,
Wait so you are saying your Inner Tie Rod Removal Tool wasn't long enough? If that's what you meant then maybe you got wrong one? I've noticed alot of different one, that's why I posted my above question.
bilzy7
32
Lynn, MA
4.0 SOHC
NAPA is the shiznit!!! Guy called a shop and told them I was his nephew so I could borrow the inner tie rod removal tool with correct size crows feet! I love it when people show trust in me and don't even know me. I will not let him down! Lol. Saved me 78 bucks so there is no way I'm not gonna bring this back in 2 hours when I'm done. I'd be done within 30 mins but I gotta let my wife have smoke breaks, watch my son, and work in the effin rain!!!
bilzy7
32
Lynn, MA
4.0 SOHC
Done! God I hate rain... Much less movement then before in my steering. I wonder if I should do the drivers side too sometime or just wait till it fails too...
Members online
Today's birthdays
Shran
April Truck of The Month
