2010 xl reg cab 4 cyl 2wd front rotors
Dirt addict
Hi, I picked up this low mileage ranger a month ago and have been going thru the basic maint. It's had brake shudder since the day I got it. I'm finally at replacing the rotors and pads. I've been on YouTube looking at how to's. I notice some ranger rotors have the wheel lugs and hubs as part of them, while others slide on to the hub and wheel lugs. Is this a model difference or a year made thing?
I ordered some rotors from summit. Hopefully I got the right ones...
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Up to 1997 it was all of them. From 98 up it was a 4x4 vs 2wd thing. The 2wd would have the hub assembly as part of the rotor.
Dirt addict
Thanks. The rotors showed up today, and of course, they were the wrong ones... I called Summit. Their customer service is top notch. Sent me a return label and will be sending the correct ones asap.
Thanks for the reply. Dead on. The 4x4's have the separate hub/rotor. The 2wd is an all in one...
Today's birthdays
Mudtruggy
May Truck of The Month
