Need help with installing my 302 back in.
84FreakRanger
Tifton, Ga
306
I just bought a 1984 Ranger for $740 with a bad 302 motor, I took it out and rebuild it. The Ranger had some cheap homemade motor mounts and frame plate. So I bought the Trans depot motor kit, But when I put them on the frame and drop the motor in and bolted on the transmission. The motor is about 1-2 inches to forward and won't go in the slot. I don't know if I have to move the motor and transmission back? Then it might be too close to the firewall. I believe that I have a FMX transmission? Any help will be appreciated Thank you.
Did anybody have to move the transmission crossmember to make everything fit?
swynx
9
lewiston idaho
Mazda
4.0
if it was right everything should just bolt together and drop in, have you compared the old and new engine mounts? they could be home made for a reason.
Big Jim M
30
Austin
4.0
Just put the ones that came with it back in!
Big Jim
Shran
April Truck of The Month
