help!
CowBoyDave
I changed by head light. GO to start everything blacks out and terminal cord furthest right sparks. What did I do?
97RangerXLT
3,937
Fishers, IN
2"
31"
Well it sounds like you shorted a wire to ground. take a look at the plug to the light and make sure none of the wires have worn insulation and are laying against anything metal.
Pics would help too...
AJ
CowBoyDave
I know this is a dumb question. But is the ground wire the negative? if so where and what does it connect to? Where could it be loose? Everything was fine until I added the new headlight.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Yes, negative cable is ground. It simply goes down and connects to the frame and/or the engine block.
