Brite Box
ajmiller
3
Hubbard, Oregon
2.9L V6
does anyone have this? can i see pics? was wondering if it actually works good. maybe considering getting one
thanks
daniel3507
74
NE Oklahoma
Engine Type
2.3 EcoBoost
2WD / 4WD
are you looking for more driving light or just for more lights to flick on when on a dark road with no other cars?
ajmiller
3
Hubbard, Oregon
2.9L V6
just driving...im already getting hella 500's i just wanted better headlights
daniel3507
74
NE Oklahoma
Engine Type
2.3 EcoBoost
2WD / 4WD
your best bet would just be those headlights you got and some auxiliary driving lights mounted down lower to light it up wider
Crane
2
Kansas City, MO
4.0L SOHC
Yea, I have some Hella 500 fog lights that are street legal because they have one of those metal shields over the bulb, I have them aimed a bit below the normal headlights and it helps a lot
ajmiller
3
Hubbard, Oregon
2.9L V6
ya im just gonna get a light bar and mount 500's on them.
thanks guys..
daniel3507
74
NE Oklahoma
Engine Type
2.3 EcoBoost
2WD / 4WD
be sure and adjust them properly so they dont blind other drivers
Original_Ranger84
TRS Banner 2012-2015
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
you don't need the bright box... all it does is leave your low beams on when your high beams are on. You can simply wireup a relay between the high and lows for the same effect.
Look at the high beam upgrade then read the bright box thing
http://www.therangerstation.com/tech_library/hibeams.html
I did this on my trucks
Beefy'sB2300
Ohio
Mazda
2.3
Original_Ranger84
20
2.8L, 3.0L
I haven't in the 2 years I have ran it. The only problem I would think you could have would be heating up the headlamp too much with both running but I haven't had a problem there either. Wiring shouldn't be an issue because the high and low beam have seperate circuits and seperate wires going to them. and the relay bypasses the high/low beam switch in the cab so that shouldn't overload.
Staff online
Members online
Shran
April Truck of The Month
