did the duraspark conversion now battery light stays on
tims tire kicker
I did the duraspark conversion battery light stays on won't charge battery took negitive cable off won't stay running put in new alternator and volt regulator now trying to trace wires down to see if any are messed up which wire do you think it could be
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Check the light Green/Red wire on the Voltage regulator that is the Battery Light wire, it should have 12volts when key is on
This turns on the alternator
When you turn on the key the battery light gets 12volts from ignition switch, the LtGreen/Red wire on the voltage regulator is its ground at this time, so light bulb lights up.
When you start the engine the alternator should produce 13volts and the LtGreen/red wire is now 13v and so is the ignition wire, so battery light now has 13volts at each connection, so it is off.
Here is a wiring diagram with the other hook ups: http://www.therangerstation.com/tech_library/EDiagrams/files/diagram_charging_1983to1985_1.JPG
tims tire kicker
it only has 2.1 v
RonD
Official TRS AI
8,370
canada
Must be a dim battery light then.
I would check fuses in cab
kimcrwbr1
46
maplevalley WA
ford
2.8l
There are only two wires necessary the large black/orange wire to the alternator should be full time hot from the battery and the field wire from the regulator to the alternator. I believe the field wire goes through the grey 8 wire connector by the ignition coil. The tech library has a troubleshooting guide but my guess it is at the grey 8 wire connector. Some guys go crazy cuttin out the old computer harness you can just splice the wire in to the regulator direct from the alternator. Are you getting battery voltage at the large connector on the alternator?
kimcrwbr1
46
maplevalley WA
ford
2.8l
The S or stator wire on the alternator should read about 8 volts when the engine is running and is not used on your engine. The white/black wire terminates at the 8 wire connector on my 83 ranger. You can use it to power up a choke thermostat so it only has power when the engine is running. (old school)
tims tire kicker
I will check it out some more when I get off work thanks for helping me on this
tims tire kicker
Did away with grey connector directly wired the two alternator wires still no charge
tims tire kicker
Got 12 volts at big connector alternator
tims tire kicker
Finally fixed it believe it or not had stator and field wired switch at alternator. Now I'm going to build custom upper intake to fit a 32/30 Weber carb I was originally going to put on an iron duke.
tims tire kicker
Had wire backword on alternator
kimcrwbr1
46
maplevalley WA
ford
2.8l
Easy enough to get them backwards. Just a word of caution the 2.8 really dont have the displacement to process fuel in a larger carb. Much over 250 cfm carb and the fuel will just drip into the manifold and puddle and create performance issues. Just put a motorcraft/autolite 2150 with a 1.08 venturi and #42 jets anything larger and you will lose the upper end performance. If you want power do the 5.0 conversion you aint gonna get it with the 2.8.
tims tire kicker
I got one of those but the venturas are to big came off 302 so I remembered a Weber I had for a 4 cylinder project
Staff online
Shran
April Truck of The Month
